1 Another spline lube question Thanks Fri Jun 07, 2019 10:20 am
Heresy23
Hi, so I gotta change my rear tire in the next day or so and I might as well do the rear splines while I have the rim off....I’ve been reading all over this forum and the internet about lubes and greases and still need advice. Should I just use the Honda m-77 product (which is still a lot of money for me to spend at 16$ at this moment )? Eventually I would rather use the Loctite moly paste but I need the cheapest option without using the completely wrong thing. I’ve seen a lot of cheap products from “liqui moly” but I haven’t found a lot of info about using their products for spline lubes....at least with the Honda product I can drive 10 min to the Honda house and buy it, I’d rather lube the final drive splines while I’m changing the tire then NOT lube .
Or I’d rather just go to Napa or pep boys... tubes are like 6$...but I think the moly content is less then 10%...
