1Back to top Go down   Hello from Brisbane! Empty Hello from Brisbane! Sat Jun 08, 2019 8:37 am
JakeS41y
JakeS41y
Hi everyone,
I recently bought a 1986 K100RT back in April and have been slowly working my way through fixing it. Don't usually post on forums but from what I've read on this one you guys have been really helpful already. Anyway here is my fix list so far
Already Fixed (after purchase)
Front Brake Master Cylinder- the little O ring leaked and corroded the whole assembly, managed to track down a 2nd hand one along with a clutch leaver & assembly for about $180 which I thought was pretty good
Rear Brake Resevoir- Had a small leak BUT made a cracking noise when I tightened it up after bleeding it and thought better replace this before it crumbles (which happened the next week) just bought a CNC alluminium one off ebay and it seems to be going strong
To Do
Rear Main Seal- Got all the parts on order, just waiting for them to arrive
Clutch Disc- Because oil leaked out from the main seal onto clutch (was like a waterfall when I removed the clutch assembly, probably should have drained oil first to avoid mess but clutch was already toast). Ordered one from Munich Motorcycles for $180~ and it arrived from WA the next day, so far very impressed with their service.
Incidental screws, washers, snaps and Orings- Most on hand, waiting for BMW to get them in for me
Oils- Engine, Clutch and Final Drive to be replaced when reassembling after RMS.
2Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Sat Jun 08, 2019 6:22 pm
Welcome to the Asylum from a little bit north of you. Plenty of help available.
3Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Sat Jun 08, 2019 6:49 pm
WelKome to the Knuthouse. Once you sort out the bits and pieces you will have a wonderful bike.
4Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Sun Jun 09, 2019 5:45 am
Welcome from the other side of the world Smile
Hello from Brisbane! Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
5Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Sun Jun 09, 2019 5:50 am
Welkom Jake,
Which part if town do you hail from?
6Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Sun Jun 09, 2019 5:52 am
Hello Jake
Another k in Brisbane
We have a little gathering soon at the pine river swap meet
7Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Sun Jun 09, 2019 6:27 am
JakeS41y
JakeS41y
Sweet, that's like 10 minutes down the road. When's that going on?
8Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Sun Jun 09, 2019 11:17 am
welcome aboard Jake
9Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Sun Jun 09, 2019 1:20 pm
Jake I don't know whether it was a one off but Matt went through around 4 rear seals which leaked. It was eventually cured by linishing the running surface as per Charlie and fitting a OEM seal and "O" ring.
10Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Sun Jun 09, 2019 11:18 pm
nope just me as a bad mechanic
11Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Mon Jun 10, 2019 12:20 am
JakeS41y
JakeS41y
MartinW wrote:Jake I don't know whether it was a one off but Matt went through around 4 rear seals which leaked. It was eventually cured by linishing the running surface as per Charlie and fitting a OEM seal and "O" ring.
Got the OEM seal and ORing from BMW today and will attempt reassembly soon (hopefully within the next week). I'll let you know how I go.
I'm going to try and make a bit of a tool to seat the seal correctly (0.5mm proud if I remember correctly) using a block of wood and a router. Will update on weather it was useful or not.
12Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Mon Jun 10, 2019 1:03 pm
No need for a router.  Just glue a piece of cardboard about 0.5mm thick from a cereal box to the block of wood after you cut a hole in the cardboard to clear the seal.  That is what I did and it worked fine.
13Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Tue Jun 11, 2019 6:43 pm
Jake
Martin got one and he just around the corner  from you
We ended up putting my BMW seal flush with the surface as the lip need to sit on the clutch basket
14Back to top Go down   Hello from Brisbane! Empty Re: Hello from Brisbane! Tue Jun 11, 2019 11:53 pm
Matt I PM'd him and let him know that I had all the gear and he was welcome to borrow it. Also let him know that I was available if he needed a hand.
