1 Fault with indecators Tue May 28, 2019 4:58 am
residentalien
I removed the front indicators to fit a headlight fairing , all wires went back as they was .
Now the right indicator works as it should , but when I turn the left ones on at the switch all 4 work at the same time , like hazard lights .
I have read all the problems in the past , and tried all there suggestions ,
Relay fuses all work fine
I did connect a wire from the battery to each side on the relay box , and just the side I had the wire come on , I thought maybe a left wire may have touched a right , to make all 4 work at the same time
Only thing I have not pulled yet is the starter motor , bike has been sat for years , but all worked ok , till I took the indicators off
