Time To Ride
Time To Ride
Wondering if anyone recognizes this unused plug under the seat.  Noticed this today, the plug looks clean like everything else in the compartment, for an unused accessory perhaps.  Bike is a 94 K75S without heated grips, the only thin not working on the bike is the low fuel light.
1994 BMW K75S  ABS
USA Bike   43,000 mi
What's the color of the plug, color of the wires, and/or maybe a picture?
Does anyone recognize this open plug? Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
Stumpy
Stumpy
Without a picture we can only make wild guesses. If it is in the box with the relays then it could be the accessory plug or the plug for the BMW alarm.
moriarti
moriarti
my gut feeling is this is the heated grips plug,this can be used to replace the plug in the fuel tank if needed,it worked for me study
Five wires in the back of the plug and one brown (earth) wire waving around free with a spade connector on it is the auxiliary connector. Alternatively, four wires on the plug is the factory fitted alarm and as Stumpy says, can be used to replace the fule tank connector on the early Ks.
Moriarti: heated grips plug is under the left side of the tank Very Happy .
moriarti
moriarti
Sorry Dai, i was sure that was put on my naughty K POST AS A POSSIBLE fault and used the Plug
conector as described to change into fuel tank connector Does anyone recognize this open plug? 177381 lol!
volador
volador
Diagnostic Plug - Black 3 pin connector usually with a blue cap
Center hole used for resetting the ABS
Same plug different bike
If it looks like this, it operates the optional mead cooler.
Does anyone recognize this open plug? Screen52
Time To Ride
Time To Ride
Thanks Dia,  looks as you said,  will sleep well tonight!
1994 BMW K75S  ABS
USA Bike   43,000 mi
