1 Trouble Removing Spark Plug Cap Fri Apr 19, 2019 2:21 am
John A
Hello all,
I changed (3/4) spark plugs on my 1985 K100 two weeks ago since I couldn't manage to get the spark plug cap (boot) off one of the plugs. At the time I didn't want to risk damaging the wiring as I was going on a trip the next day and the engine was running fine the way it was. I was just doing some springtime maintenance before hitting the road. I now have more time to work on the bike, which is still running fine, and want to change that spark plug. I know that I could replace the wiring, caps, and coils. However, the bike still has the original caps on it and I want to preserve that if at all possible.
Anyway back to the problem description;
When I was pulling the caps off the plugs, it was very difficult to dislodge them. After pulling the first I saw quite a large amount of corrosion built up on the spark plug terminal. It did have the screw on cap so I don't know why it would be corroding there, except maybe from age?? I was able to dislodge 3 of the 4 and sprayed them with contact cleaner before hitting them with a brass brush to clean off the metal connection. I have the bike on the center stand and am currently almost pulling it over trying to pull the last cap off. It can rotate freely but is unable to come off the spark plug. I have pulled and pulled and pulled, but have thus far been unable to make the cap budge more than an eighth of an inch, which it was able to do before. Does anyone have a suggestion for how I could get lubrication into the cap without destroying it? If not, I suppose it might be time for new caps and wires.
Thank you for your advice in advance, and sorry if I rambled on a bit much.
1985 BMW K100RT Vin: 0051738 (old style tank)
1982 Suzuki GS650GL
