1Back to top Go down   Bosch fuel pump / tow bar Empty Bosch fuel pump / tow bar Thu Apr 04, 2019 2:48 am
Patto89
Patto89
hi ya,
i am after a fuel  pump bosch 058046300 for 89 k100 lt , does any one have a spare known to work they want to part with ? only need the pump have the filter damper etc. please let us know , happy to pay a fair price ? plus post hopefully one of the aussie guys have one ,.
 Also do have a tow bar that was fitted up to the above  and been in dry shed for years if any one is interested , The plug and wires are there ,and probable very light surface rust,
These pumps seam to be hard to find with paying an arm and leg !
Cheers  Patto
2Back to top Go down   Bosch fuel pump / tow bar Empty Re: Bosch fuel pump / tow bar Thu Apr 04, 2019 3:00 am
Here are some Australian cars that suit
HOLDEN Commodore VK EFI, VL turbo and non turbo, VN onwards V6 and V8 sedan wagon statesman
HOLDEN Camira JD JE Astra Calibra
FORD Falcon XE XF EFI Sedan only
FERRARI 412i Coupe
NISSAN Skyline Pintara Pulsar Bluebird
VL Dunnydore is the best fit
3Back to top Go down   Bosch fuel pump / tow bar Empty Re: Bosch fuel pump / tow bar Thu Apr 04, 2019 3:13 am
Patto89
Patto89
thanks Rick,
I did go over a few lists that people had compiled and found most were external pumps
the old girl sat for to long and got the dreaded damper melt down , takes ages to clean that out ! dumb mistake that i wont do again,  live and learn,
now check injector s and get battery and hopefully back on the road,
Melbourne freeway ( carparks )  are doing my head in !
4Back to top Go down   Bosch fuel pump / tow bar Empty Fuel pump tow bar Thu Apr 04, 2019 8:41 am
daveyson
daveyson
Hi Patto
Are any extra holes required for the tow bar,  or what's involved to attach it?  I've got a pump if your interested in a swap.  Pm for my number or pm me yours if your interested.
Regards David
 ~120,000 km
5Back to top Go down   Bosch fuel pump / tow bar Empty Re: Bosch fuel pump / tow bar Thu Apr 04, 2019 7:36 pm
daveyson wrote:Hi Patto
Regards David
I have tow bar for both my K1100LT and my 84 K100RT.
No hole drilling required, they bolt on. A K100LT is most likely bolted to footrest hangers and with stabilisers to the Z carrier mount points. Some use a J bar bolted to the stand assembly and again stabilisers but the J bar is generally used for the paralever as in 16v Ks.
Not a lot of work to attach them. Biggest part is figuring it out due to absence of  any instructions.
6Back to top Go down   Bosch fuel pump / tow bar Empty Re: Bosch fuel pump / tow bar Thu Apr 04, 2019 10:37 pm
daveyson
daveyson
Good one,  thanks.
 ~120,000 km
7Back to top Go down   Bosch fuel pump / tow bar Empty Re: Bosch fuel pump / tow bar Fri Apr 05, 2019 5:01 am
daveyson wrote:Good one,  thanks.
The K100 2v footplate hangers are hard mounted.
So too are K100 4v BUT they have Paralever rear and the size is different so 2v tow bar does not fit.
I am almost certain toot hat tow bar for early 2v may not fit later v. Will Crean [88 here] may be able to comment on that as he was using my early 2v one to sort on for his 88 K100LT.
The K1100 ABS2 the whole footplate assembly mounts on the 4 battery location threads on top of the transmission and cannot take a tow bar. It must be be mounted elsewhere and the J bar under the stand assembly is the best place for that to avoid handling issues.
8Back to top Go down   Bosch fuel pump / tow bar Empty Re: Bosch fuel pump / tow bar Sun Aug 25, 2019 2:47 am
Patto89
Patto89
hi daveyson, of a88 lt its not backyard built looks fine not charrlie99 clean but ok
bm ringwood getting me out of trouble but if your wheels good and abs will go on easy swap we both pay postage < or depending how far from yarra ranges Mooroolbark just meet up and swap or what ever Cg
heers, pretty sure its ok t
for 85 rt, again probobly a Rick G,  question
9Back to top Go down   Bosch fuel pump / tow bar Empty Wheel tow bar Sun Aug 25, 2019 4:18 am
daveyson
daveyson
Goodo,  I can be in mooroolbark next week, will pm contact details later when I know more
Regards David
 ~120,000 km
