As Al says, they are all different. Mine has a four point QD atachment system that retains the set up, but I have never considered detaching the chair even so.
Once the l/h fairing lower is off you may be surprised at how much working room there is (especially if you are prepared to relax your standards around working comfort, NB. I am built like a snake with malnutrition).
On that side of the bike with my l/h tub in place I have recently:
- replaced all fuel lines
- replaced the fuel injectors (and given the surroundings a decent clean)
- removed the rear wheel
- replaced exhaust headers
- replaced plugs and leads
- performed compression test
- fitted a steering damper and brackets
- adjusted bike lean
- drilled the tub for routing battery leads to chair
Where I have had to bite the bullet:
- cam cover off
- gasket replacement
- valve gap measure
- adjust toe in *
- level chair *
- drill and extract sheared cam cover bolt *
- helicoil cam cover bolt hole *;
I have disconnected chair power, unbolted the box from the chassis, slid the tub backwards onto a car creeper to move it out the way.
Only * jobs really needed that, the others could have been done at a pinch, it was just easier on balance to shift the tub.
You don’t say whether the bike still has a centre stand, mine doesn’t so when I loosened the chair fittings I had to stabilise the bike with ratchet straps (rafters to chassis). With my QD fittings, accurate re-attachment wouldn’t have been an issue, but otherwise I wouldn’t have thought there was enough stability to provide a fixed reference point for re-attach (but that again will probably depend on how your fittings are set up).
Finally, my chair electrics route under the chassis into a mud encrusted poor quality connector block and housing (which I will upgrade and re-site when I find something suitable) inside the chair wheel arch. To disconnect the electrics the first time I had to jack up the wheel side and wear goggles. The next time I just unbolted the wheel arch and left it hanging from the chassis while I slid the box off.
Hope this helps.
Cheers, Stu
Last edited by tinyspuds on Tue Mar 12, 2019 2:17 am; edited 1 time in total (Reason for editing : completeness)
