1 frame/model interchange Thu Jan 24, 2019 4:23 am
tinyspuds
Hi all,
My 1985 8 valve 100 RT based outfit may have to go to the workbench in the sky.
The outfit components are all Hedingham and top notch engineering all recently reburbished by me.
I have had what may turn out to be a significant mechanical event and I can’t be without the ride for the duration. While I’m working thru the issues I will keep my eye out for a replacement tug.
My question is: what other models / years will accept my Leading links and Hed subframe as a straight(ish) substitution?
(same headstock and bearing config and same chassis architecture (the sub frame hi jacks the engine stressed member mounting points)).
Cheers for all guidance, either direct or pointing to a resource. Stu.
