Number of posts : 7963
mmgee123 wrote: 92KK 84WW Olaf wrote:But did he replace the fuel filter? And the filter basket under the pump.
I have had 3 Ks where the PO has done this stuff and done it wrong so I would go back in the tank and see whats happening there.
but would something bad in the fuel system just make it instantly die? i figured it’d sputter out some if it was something to do with fuel. but i do agree with you just because he said it was done doesn’t mean it was done right.
The fuel pump sits in a vibration damper and in a plastic mount that has 5/6 bolts on it to clamp around the damper. This then has a small mesh filter basket that clips onto a recess in the vibration damper. The whole assembly clips into a holder inside the tank.
A few things can happen here:
1: Its not clipped in correctly and so runs out of fuel while the tank is half full, because the intake is above the fuel level.
2: The basket can be clogged up with fine grit, meaning fuel seeps in while the bike is parked, but at a much too slow rate for running and once the fuel in the basket is used, it cuts out due to lack of fuel.
3: The filter could be blocked with crap, the pump pumps through the filter to the injection rail.
4: The 'new' pump may actually be a dud used pump.
5: The electrical plug to the tank may be faulty.
1 2 and 3 have happened to me and with 1 [pump was loose inside the tank!] and 2 the cut out was instant and spluttering.
1971 Yamaha 125 YAS-1
