1Back to top Go down   bep 3.0 with motogadget m unit Empty bep 3.0 with motogadget m unit Sun Dec 02, 2018 4:42 am
lechicho55
lechicho55
good day.  I just started redoing my k and was planning on getting a motogadget m unit for it, not sure with model yet.  I have seen that one can use a beep 3.0 to work in conjunction with the m unit.  What is the benefit of this.  I figured the m unit would have everything that is needed for speedometer, tach, lighting, gear selection, gas gauge.  Well I'm not sure how the gas gauge works or would work with an appropriate digital cluster.  Thanks for the help.
2Back to top Go down   bep 3.0 with motogadget m unit Empty Re: bep 3.0 with motogadget m unit Sun Dec 02, 2018 10:06 am
Many forum members have struggled with or used successfully the Motogadget M Unit switches and 'brain', and BEP, as well as other, instruments, like Acewell, on their K bikes. This is covered ad nauseum when you type either key word into the forum's search engine. It's a good read,  you'll get the details, and it will save having to explain the myriad details in another thread. Then you can reply with questions to those folk who've done the deed already.
3Back to top Go down   bep 3.0 with motogadget m unit Empty Re: bep 3.0 with motogadget m unit Sun Dec 02, 2018 2:09 pm
lechicho55
lechicho55
oh word.  thanks
