Go to page : 1, 2, 3, 4
52 Re: Another DJP Mon Nov 16, 2020 8:24 pm
53 Re: Another DJP Tue Nov 17, 2020 8:41 am
He walked into that one...
54 Re: Another DJP Wed Sep 22, 2021 11:39 pm
Packo
Well???
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
55 Re: Another DJP Thu Sep 23, 2021 4:01 am
done nothing Packo, got all the bits but have not got any room to attach it. Need to sell K1200 to make room.
K100 RS
K100RS with 1100 motor Premier sidecar
K100 RT KRAUSER FAIRING
R1200GS
650 Vstrom
56 Re: Another DJP Thu Sep 23, 2021 4:13 am
Packo
MMMmmmm!!! I had better keep a close eye on this thread, poor excuse Waz, if it doesn't get done in lockdown.........
______________
83 K100 HRD Outfit
1992 K1100 Outfit
1983 K100 Basic
57 Re: Another DJP Thu Sep 23, 2021 11:20 pm
OK Packo, I will start this afternoon after I get a sump back on the other one. If you get a minute can you please measure your lead and track for me? I have been wanting to measure Al's but we are all locked down. I used these last time but it was a bit of a wanderer, I think it was too wide it weaved around a bit.
K100 RS
R1200GS
650 Vstrom
58 Re: Another DJP Thu Sep 23, 2021 11:41 pm
Have these plans been certified ? I, for one was certified years ago.
1983 K100 basic vin 0003960 colour red GONE
59 Re: Another DJP Fri Sep 24, 2021 12:43 am
No Stan not certified, but I should be too.
K100 RS
R1200GS
650 Vstrom
60 Re: Another DJP Fri Sep 24, 2021 1:29 am
Packo
Waz,
Track is 1370mm centre to centre of tyres
Lead is 285mm
The track width is generally around that (1350 ish) so that the outfit will straddle the two wheeled tracks without having to run one wheel up on the middle hump. Generally made to fit the 4x4 track ie Landcruiser.
I think the regs say that overall outfit width from RH mirror to widest part of sidecar must not exceed 1850 but it would pay to check that.
Supposed to be good info available here: -R&c[0]=AT3U_jbavtgMHsVo6_KqXeregcdMrC1q2L-KoVudrYS4CnUQLKRrLxrv1fQP_jaSta0iTj-_ijB0GCaZv5bvnqmPo4C0aKITyWsE1sCDo7UZdyHz25PxjU3FZTZeLYaMnkDIKjamAoO78DUiacbkYEfxS1ga-eEN5Vdp_cFa1TkEY6rN9hd6BTdSsyUhaMIMT9kOJEZbYeqa]http://www.threewheelsbetter.uk but I haven't read it
Lead is 285mm
______________
83 K100 HRD Outfit
1992 K1100 Outfit
1983 K100 Basic
61 Re: Another DJP Fri Sep 24, 2021 1:50 am
K100 RS
R1200GS
650 Vstrom
62 Re: Another DJP Fri Sep 24, 2021 2:18 am
I'll get the tape measure out and do some measurements for you Waz.
I was recently fidgeting about and actually did a measurement of my toe in. It rode ok but was sometimes a bit of work so I thought I'd at least check. Let's just say that I increased the toe in by quite a bit. Still runs straight, easily. Steering on right turns is much lighter and easier on my shoulders. Left turns feel little different and if I push it harder, the sidecar wheel lifts a little anyway, then the toein makes no difference as the wheel isn't contacting the road.
'93 K1100LT
63 Re: Another DJP Fri Sep 24, 2021 2:38 am
So I got my 6ft straight edge, large steel square and tape measure on the job.
The track on mine is 1370mm from tyre centre to centre.
Sidecar lead is 340mm
Overall width from sidecar mudguard to the outside edge of my mirror is 1850mm. Measuring to the end of the barend weight or outside edge of the pannier would be wider. Remember that mine is a one and a half, yours is a single, you have plenty of width to play with.
When I bought the Leigh Hollamby outfit that supplied all the good bits this sidecar chassis did originally have a single DJP body on it(its not a DJP chassis). I had the chassis widened for the HRD one and a half body and modded the shock mounting so it fits under the HRD mudguard.
Hope it helps.
Hope it helps.
64 Re: Another DJP Fri Sep 24, 2021 3:19 am
That's a big help Thank you. I had similar track to you and Packo but I only had 250 lead, looks like the smaller lead might have been the cause of wandering.
K100 RS
R1200GS
650 Vstrom
65 Re: Another DJP Fri Sep 24, 2021 8:43 pm
Gaz wrote:Good to hear that the latest project has fired up Waz.
I guess you were pretty excited judging by the number of posts.
If you decide to tackle the Alpine Rally again in an outfit let me know and I'll definitely be along for the ride.
Remember what happened last time? We need more people to find the wheel anyway.
'93 K1100LT
66 Re: Another DJP Fri Sep 24, 2021 9:12 pm
That wheel went a long way on its own. I will never forget that, I don’t know what scared me more. There was the shaking itself violently before wheel departed or trying to stay on the road with only two wheels or the most terrifying was when you doubled me back on your sidecar and you overtook two sports bikes through the mountains, both riders looked at me in disbelief as you rounded them up. After being on the back of yours if made my realise mine didn’t handle very well even with three wheels. I still appreciate the double but my eyes where the size of dinner plates.
K100 RS
R1200GS
650 Vstrom
67 Another DJP Fri Sep 24, 2021 9:22 pm
Hey Waz, Now you know how Al's dogs feel when they are in the side car.
Cheers Tom
Cheers Tom
68 Re: Another DJP Sat Sep 25, 2021 11:37 pm
Good man, Waz.
My project seems to be going backwards at times lately, with everything else going on. Hopefully it won't be too far away.
69 Re: Another DJP Sun Sep 26, 2021 2:52 am
Good to hear, how close is it Sean?
I went out to do a 5 minute job, bolt a new mini drum brake on but the backing plate was in wrong place. Spent hours cutting, grinding and welding, still not bolted on. 5 minute jobs take me all day.
K100 RS
R1200GS
650 Vstrom
70 Re: Another DJP Mon Oct 18, 2021 2:56 am
K100 RS
R1200GS
650 Vstrom
71 Re: Another DJP Mon Oct 18, 2021 8:11 pm
Looking good, Waz.
Where do you find these DJPs in such good nick? What year is it, do you know?
Is the bike ex-police or are you going for the solo seat option?
My K project seems to be going backwards at the moment. The sidecar is pretty much ready to bolt on, with some cutting and welding. The sub frame is ready, the rear wheel adaptor installed. The bike is running, though needs some tweaks. In the meantime though, my brother has given me a Hardly Driveable and I would like to get it on the road before he passes, so the sidecar intended for the K100 will now be used on the Evo.
However, I happened across yet another sidecar in the wilds of Stanthorpe from a certain chap who has had a bit to do with BMWs over the years..and it's in pretty good nick actually, so I hope to get to it over the warmer months and put it on the K bike.
Glad you asked, aren't you....
72 Re: Another DJP Tue Oct 19, 2021 1:56 am
Yes I am glad I asked, glad you have projects going. I picked DJP up from Rockman, not sure of the year the serial numbers and plate are painted over, the bike is not a police bike (nothing wrong with police bikes) its an RS. I put the single seat and box on with LT bars looks funny but its comfortable. So you are putting the silver DJP on Tim's Hardly and Ricks red sidecar one on the K100 and the Triumph has one fitted as well. I am so envious.
K100 RS
R1200GS
650 Vstrom
73 Re: Another DJP Wed Jan 12, 2022 6:53 pm
Packo
Nothing reported since October. Don't tell me the wheels have fallen off again!!!!
______________
83 K100 HRD Outfit
1992 K1100 Outfit
1983 K100 Basic
74 Re: Another DJP Wed Jan 12, 2022 7:30 pm
75 Another DJP Wed Jan 12, 2022 8:13 pm
76 Re: Another DJP Wed Jan 12, 2022 9:04 pm
K100 RS
R1200GS
650 Vstrom
77 Another DJP Thu Jan 13, 2022 1:43 am
Looking very good Waz. Is it going to be painted red? Keep up the good work. Cheers Tom
78 Re: Another DJP Thu Jan 13, 2022 2:34 am
Packo
Good news Waz, keep chipping away at it and all of a sudden you will realise that you are doing the finishing touches.
Appears that most of the leg/fab work has now been done, looking good
Nothing wrong in sticking the boat on as is or just strap some ballast on the chassis and going for a squirt around the block to see how it tracks etc - just a little reward for your efforts so far; we all need a bit of encouragement every now & then on these big projects
If it is all good other than "tweeking" it should give you renewed enthusiasm for the electrics & painting
Enquiring minds need to know what progress is being made, you never know we might even encourage you
I will look forward to the next update
______________
83 K100 HRD Outfit
1992 K1100 Outfit
1983 K100 Basic
79 Re: Another DJP Thu Jan 13, 2022 8:17 pm
Looking good, Waz.
Will you do the top coats and finishing yourself?
Any idea what year model the DJP is?
Schoorn.
Schoorn.
80 Re: Another DJP Sun Jan 16, 2022 11:37 pm
Dont know year model, I will try and paint it black but being out in the oen its gunna be a bit rough but its not a show bike.
K100 RS
R1200GS
650 Vstrom
81 Re: Another DJP Fri Jul 01, 2022 7:50 pm
Packo
AND !!!!!
______________
83 K100 HRD Outfit
1992 K1100 Outfit
1983 K100 Basic
82 Re: Another DJP Sun Jul 03, 2022 2:00 am
Still nothing happening yet
K100 RS
R1200GS
650 Vstrom
83 Re: Another DJP Sun Jul 03, 2022 2:01 am
Nothing happening yet.
K100 RS
R1200GS
650 Vstrom
84 Re: Another DJP Sun Jul 03, 2022 6:47 am
Nothing happening yet?
85 Re: Another DJP Mon Jul 04, 2022 1:11 am
Just to be clear.
Nothing happening ..... yet?
86 Re: Another DJP Mon Jul 04, 2022 2:31 am
Are you sure that this is correct....nothing?
87 Re: Another DJP Mon Jul 04, 2022 2:59 am
Also... echt gar nichts passiert? ( erledigt)
88 Re: Another DJP Sat Jul 09, 2022 8:33 am
Ní dhéanfaidh aon ní ag tarlú fós?
89 Re: Another DJP Fri Jul 29, 2022 10:10 am
Looks like there's nothing happening yet.
'93 K1100LT
90 Re: Another DJP Sun Jul 31, 2022 5:52 pm
I sold two r1100 bikes to make room in my little shed to work on it but before long I got another K100 and 1200gs, no room again. I have plans to move it in a couple of weeks to a shed where I can paint bottom half and vynal wrap the topside of sidecar body, fit steering damper and a couple of little jobs to finish it.
Will see some progress in September.
K100 RS
R1200GS
650 Vstrom
91 Re: Another DJP Sun Jul 31, 2022 6:57 pm
This means that things MAY be happening.
92 Re: Another DJP Sun Jul 31, 2022 9:47 pm
September which year?
93 Re: Another DJP Thu Aug 04, 2022 10:45 pm
This year, how are the ribs going
K100 RS
R1200GS
650 Vstrom
94 Re: Another DJP Fri Aug 05, 2022 2:47 am
'93 K1100LT
95 Re: Another DJP Fri Aug 05, 2022 3:59 am
Waz wrote:This year, how are the ribs going
Ribs are good but not ready for any long distance trips yet.
96 Re: Another DJP Fri Aug 05, 2022 4:03 am
97 Re: Another DJP Thu Sep 01, 2022 10:53 am
tinyspuds
Looking forward to this month’s update
98 Re: Another DJP Thu Sep 01, 2022 6:41 pm
Packo
+1 but my updates are closer to annual
______________
83 K100 HRD Outfit
1992 K1100 Outfit
1983 K100 Basic
99 Re: Another DJP Thu Sep 01, 2022 7:53 pm
Are we there yet?
100 Re: Another DJP Sun Sep 04, 2022 5:50 am
Dim byd yn digwydd eto?
101 Re: Another DJP Fri Sep 16, 2022 4:42 am
K100 RS
R1200GS
650 Vstrom
K100-forum.com » Technical, repair and troubleshooting » Everything about adding a chair(sidecar) on a K Bike..... » Another DJP
