1Back to top Go down   Tire valve stems Empty Tire valve stems Wed Oct 31, 2018 4:43 pm
BooG
BooG
Tubeless BT45 on front is letting air by through the stem on my K75.
Can I get a tire shop to do a stem replacement?
DIY?
2Back to top Go down   Tire valve stems Empty Re: Tire valve stems Wed Oct 31, 2018 5:13 pm
nobbylon
nobbylon
get a new stem fitted or replace the stem inner yourself
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
3Back to top Go down   Tire valve stems Empty Re: Tire valve stems Wed Oct 31, 2018 5:21 pm
Yes, but if you are using right angle valve stems use the metal bolt in ones. The rubber pull through right angle ones can fail where they go into the rim. The reason that they split is that when you inflate or check the pressure you are pushing on them and it can eventually cause them to tear and leak. I've had a front one rapidly deflate at highway speed.
4Back to top Go down   Tire valve stems Empty Re: Tire valve stems Wed Oct 31, 2018 5:29 pm
If you're still running the original factory stems you are trusting your life and well-being to 30 year old rubber.
I run metal valve stems on all of my bikes. Best done when installing new tires.
5Back to top Go down   Tire valve stems Empty Re: Tire valve stems Wed Oct 31, 2018 8:09 pm
mike d
I had this on the front BT45 tyre of my K1100 a month or so ago. Took it to a local bike shop that has wheel changing facilities and they chopped off the old rubber valve, removed the tyre, fitted a new valve.
Total charge - absolutely free. his comment was it's only a valve. I have bought and had tyres fitted there before, for both my K1100 and R1150 RT (to loose wheels). Very clean workshop and careful working procedure.
Obviously going back when I need new tyres.
Mike
6Back to top Go down   Tire valve stems Empty Re: Tire valve stems Wed Oct 31, 2018 8:47 pm
I keep a small supply of 15mm base BMW rubber stems and replace them every other tyre change, and have the lever tool that pulls the stem through the rim. It's a good idea to have your own simple core removal tool in your kit as well so you can replace the sometimes dodgy odd one yourself.
Metal stems are da biz too, but since I keep 'em fresh....
