1Back to top Go down   possible bad earth issues Empty possible bad earth issues Sun Oct 21, 2018 5:48 am
Georgej1000
Georgej1000
Hi all, I'm having some issues with the k bike. I'm charging up the battery after a winter in the shed, connect every thing up and she started on the first wind ( I love my  k bike) however the next day i have to charge the battery up again. took it out  of the shed for a short run round the yard and suddenly shes dead, no power and the battery seems to be flat again. but as i connect the charger to the battery in bike suddenly every thing comes back. so at first glance this is a bad earth. I have also put new brushes into and cleaned the starter motor so I don't think the issue is there. the earth strap to the seems to be fine so where else could i have earth problems?
look forward to the your suggestions
George
2Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Sun Oct 21, 2018 6:01 am
It might be a good idea to connect a voltmetre to the battery and to check the voltage at the battery's terminals after a full charge, then charger off/key on, then immediately afterwards, what the voltage of the battery drops to when the starter begins its spin when you press 'go'. Perhaps it's simply a weak cell in the battery, making the batttery appear healthy after a charge but revealing the weakness when a load is placed on it.
3Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Sun Oct 21, 2018 6:04 am
73MOH
73MOH
you could try taking the kill switch (behind starter  button) apart and drowning it in contact cleaner
edit.. reread your post... wont be that if you had no accessory power
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
4Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Sun Oct 21, 2018 7:16 am
I would be testing the battery first of all it should read 12.6v after siting for 4 hours after the charger is removed and no less than 10.5 v when the starter is engaged. One other possibility is the ignition switch but my money is on the battery.
5Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Sun Oct 21, 2018 10:50 am
Here in the US you can take the battery to an auto parts store and they will load test it for free.
6Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Sun Oct 21, 2018 10:56 am
Your battery is probably shot.  If you let it sit in the shed all winter with anything less than a full charge on it it will self discharge and then the plates will sulfate, accelerating the self discharge.
I have worked in a boatyard, and seen this problem every spring on dozens of improperly stored batteries.  You can sort of make it look good, but it will never be reliable again.
Moral of this story, always put a FULL charge on your battery when you put into storage, and trickle charge for a day once a month during storage.
7Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Sun Oct 21, 2018 9:48 pm
What .75 says. If you store the bike for months at a time, one of these is a good idea:
http://www.oxford-shop.co.uk/cat267_1.htm
Hook it up and forget it. I've got one and it spends most of its time attached to the Bandit.
8Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Mon Oct 22, 2018 8:46 am
Dai wrote:What .75 says. If you store the bike for months at a time, one of these is a good idea:
Why not just keep riding it........! That's what happens when you have a K....
9Back to top Go down   possible bad earth issues Empty possible bad earth issues Tue Oct 23, 2018 4:24 am
Georgej1000
Georgej1000
Hi Guys thanks for the reply's. I had the battery tested and it tested ok but as was mentioned that's not under load.
so today I put the battery back in after a good 12-14  charge all looked good until I hit the stater then all life was gone again.
one thing I forgot to mention was as I connect the positive terminal there is an audible click from the relay box under the tank. I'm fairly certain its the starter relay. now as I mentioned before ( I think) when I was having this problem I was using a test probe to try to track whats going on. when I touched the test probe to the input side of the starter relay  i get light on the probe as you would expect , but on the negative side suddenly i have power back. suspecting a earth problem and reading another post here about the stater motor brushes being an issue,  I changed them and the problem went away. but I still have a battery problem.
10Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Tue Oct 23, 2018 9:01 am
mike d
How was the test performed. As Duck mentioned it should be a Load Test. In the UK many Tyre/Battery outlets will load test your battery FOC, on the basis that you will probably buy a new battery from them.
Mike
11Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Tue Oct 23, 2018 4:56 pm
Anything other than a load test on your battery is worthless.  The worst battery will show a full voltage after time on a charger.  The problem is that there is no real power being stored, and the voltage drops almost instantly when any current is removed from the battery.
12Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Tue Oct 23, 2018 8:43 pm
Point-Seven-five wrote:Anything other than a load test on your battery is worthless.  The worst battery will show a full voltage after time on a charger.  The problem is that there is no real power being stored, and the voltage drops almost instantly when any current is removed from the battery.
Mostly true, but at the extreme worst, a battery I tested a couple of days ago showed 6.5V after a day and a half on a hefty charger. Funny, but it wouldn't deliver anything measurable on my load tester!
Smile
13Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Wed Oct 24, 2018 4:00 am
Smile
possible bad earth issues 44271
yep id say stuffed Bill
14Back to top Go down   possible bad earth issues Empty Re: possible bad earth issues Wed Oct 24, 2018 7:08 am
It'll make a good paperweight. Maybe one for holding down a workshop manual?
