1 Warning light problem Wed Jun 23, 2010 7:19 pm
SRD
1991 K100LT 8v ABS
I've cured a starting problem, (replaced the fuel injection control unit under the seat; bike now runs fine and passed MOT with flying colours), but I am left with a problem with the two red warning lights, (bulb monitoring light and the un-named one at the bottom left of the speedo).
Both lights come on with the ignition and stay lit until I move off and apply the brakes, as expected. However, instead of going out, both then start to flash together, around 1 second on, 1 second off. Normally, this would indicate a faulty tail / brake light, but all the lights work OK.
I will check the connections on the bulb monitoring unit, but is there anything else that can cause this problem?
Simon
Simon
