Number of posts : 7963
duck wrote:Some other tricks to try:
Soak with penetrating oil.
Heat it up with a butane torch.
Vise-Grips
Pounding a high quality Torx bit into a stripped Allen head has been known to work.
And swearing. Lots and lots of swearing.
I had a temp sensor break off in that hole over the summer when removing it for a coolant change. An Easy-Out did the trick with surprisingly little torque.
Best bet is slacken off the bottom hose clamp and drain it that way. The drain plug and temp sensor in the drain plug hole seem to have a habit of going wrong.
1971 Yamaha 125 YAS-1
