1 weld on driveshaft repair flanges Fri May 21, 2010 9:41 pm
robinm
Has any one done this? Welded on a replacement spline as available from Motobins?I have a drive shaft at the engineers at the moment having the end turned off it and a new end welded on, but the engineer is a bit concerned about the heat from the welding process affecting the rubber in the end of the drive shaft. Any one have any experience doing this?
