1Back to top Go down   1983 K100 Upgrades Empty 1983 K100 Upgrades Tue Sep 18, 2018 10:03 am
redrockmania
redrockmania
Have just fitted a 4.5 x 18 3 spoke rim off a 2000 R1100RT with a new Pirelli Angel GT 160/60 R18. I left the original wheel/diff spacer on and have about 3mm clearance on the right side of the tyre to the closest part of the swing arm - I can live with that. The clearance on the left side is good due to earlier mods I did to the exhaust system. I have replaced the original muffler and collector with a BKSSpeedworks collector (beautifully made and compact) and a Delkevic oval carbon fibre silencer/muffler. The muffler extremely light and slightly upswept. I made an aluminium spacer to fix the muffler body to the left footpegs bracket.
Plans for the front end include upgrading brakes but retaining original forks. Have a 20mm (K1100) front master cylinder in transit and will fit some mounting brackets I machined so I can fit a pair of new Brembo P4 30/34 C 4 pot callipers. I decided against changing to a non-BMW master cylinder because it requires fitting of non original switchgear which creates a series of electrical problems to be solved. I have a 3 spoke BMW 3.50 x 17 from rim and new radial tyre. Will look in to practicality of fitting them to the K100 front end.  If too difficult will either source a K1100 front end or keep it for a 1995 Suzuki GSXR1100 front end I have as a option for a part restored 1985 K100RS.
Plenty more to do - Solve the cut out when hot problem - looking at Hall Effect Sensor - thermostat - Coolant Temperature Sensor - Valve clearances.
Will try to hook up with the Northern Tablelands gathering in November - I'm 14 km from Uralla these days.
2Back to top Go down   1983 K100 Upgrades Empty Re: 1983 K100 Upgrades Thu Sep 20, 2018 6:57 am
You have a 3.5 front 17"? three spoke. I thought it would have been an 18"?? So what size tyre does that allow? Would it run a 120??
3Back to top Go down   1983 K100 Upgrades Empty Re: 1983 K100 Upgrades Thu Sep 20, 2018 7:07 am
K75cster wrote:You have a 3.5 front 17"? three spoke. I thought it would have been an 18"?? So what size tyre does that allow? Would it run a 120??
3.5x17 is from a K100RS-16V or K1100RS. A 120/70ZR17 is the tyre size. It will not fit to any standard K75 or K100 fork. Bearings and/or a machined axle would be required. Then there is the issue of four piston calipers over the required 305mm floating discs, which adequately machined spacers would overcome.
4Back to top Go down   1983 K100 Upgrades Empty 17" 3 spoke rim tyre size Thu Sep 20, 2018 9:04 pm
redrockmania
redrockmania
Two Wheels Better is correct about the front tyre size for the 17" wheel. My plan is to fit the 17"  front 3 spoke rim to a 1995 GXS1100R front end I have. This at a later stage will go on the other K100 - a 1985 model. For the 1983 K100 I'll need to look into a suitable 18" front rim able to take a radial tyre and suitable for the K100 1980 front end - otherwise I'll have to consider the K1100 front end. Time for more research.
5Back to top Go down   1983 K100 Upgrades Empty Re: 1983 K100 Upgrades Sat Sep 22, 2018 7:13 pm
Wasn't the stock GSX1100 front wheel a three spoke? That would match the R1100 rear in looks.
6Back to top Go down   1983 K100 Upgrades Empty K100 Upgrades Sun Sep 23, 2018 8:20 pm
redrockmania
redrockmania
K75cster you are correct. At the time of purchasing the 3 spoke front BMW wheel rim I was obsessing about trying to match the front wheel with the newly acquired rear 3 spoke BMW wheel. I'll source the 3 spoke GSXR1100 front wheel. This will make the process of fitting the GSXR wheel to the GSXR forks far easier, quicker and cheaper. I already have 6 pot callipers, suitable new discs and front mudguard. A further advantage is that this will leave me with 2 complete K100 front ends - one in situ on one bike and one ready to fit/or as a parts source.
I'll proceed with the "83 machine first and fit the 20mm master cylinder, do the K1100 throttle system modifications (throttle handle, cable and judicious bending/fitting) and then fit the gold 4 pot Brembo callipers with my custom calliper mounting plate. I'm going to stick with the original BMW rim and discs because my adapter plate permits the 4 pot callipers to be correctly positioned to the disc surface.
At a later stage will fit the GSXR1100 front end to the "85 machine. Two issues to address here - modification of the steering stem for a good fit and possibly needing to move the tank back a bit to allow for the GSXR fork on full lock.
