1Back to top Go down   K100Rs mirror fixing Empty K100Rs mirror fixing Fri Jul 20 2018, 12:41
nobbylon
nobbylon
I know there are 2 types of mirror fixing the later ones having a spring clip pushed on via the indicator lens opening.
Does the earlier one just hold by interference fit between the metal c clip on the ball stem and the tube it sits in? thanks for any help, john
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
2Back to top Go down   K100Rs mirror fixing Empty Re: K100Rs mirror fixing Fri Jul 20 2018, 14:41
nobbylon
nobbylon
I decided to fix this backing plate myself. I drilled a pilot hole into the shaft and screwed in a filed down self tapper in stainless. I made the clip from a bicycle spoke. Not pretty but it’s not seen and works. Result!
K100Rs mirror fixing 4705d310
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
3Back to top Go down   K100Rs mirror fixing Empty Re: K100Rs mirror fixing Fri Jul 20 2018, 15:43
Snod Blatter
Snod Blatter
That looks like a great fix to me K100Rs mirror fixing 112350
4Back to top Go down   K100Rs mirror fixing Empty Re: K100Rs mirror fixing Fri Jul 20 2018, 16:49
This is how I modified my mirror pods, I removed the plastic insert from the mirror holding ball and drilled and tapped M5
K100Rs mirror fixing Sam_1610
Then I cut away part of the 'reflector' so that I could access the screw with an Allen key.
K100Rs mirror fixing Sam_1611
Now, whenever I need to remove a mirror, I just undo the screw and pull the mirror out, it saves a lot of hassle (and broken mirrors!).
5Back to top Go down   K100Rs mirror fixing Empty Re: K100Rs mirror fixing Fri Jul 20 2018, 22:39
K100Rs mirror fixing 112350  onya Paul   good mod
6Back to top Go down   K100Rs mirror fixing Empty Re: K100Rs mirror fixing Sat Jul 21 2018, 02:25
nobbylon
nobbylon
The only downside with that mod Paul is that the screw could get stuck in the ball joint and then when trying to undo it would, knowing my luck just spin the ball!
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
7Back to top Go down   K100Rs mirror fixing Empty Re: K100Rs mirror fixing Tue Jul 24 2018, 17:26
nobbylon wrote:The only downside with that mod Paul is that the screw could get stuck in the ball joint and then when trying to undo it would, knowing my luck just spin the ball!
Actually the ball spigot has two flats that locate in the shaped hole in the pod chassis so it can't rotate.
8Back to top Go down   K100Rs mirror fixing Empty Re: K100Rs mirror fixing Tue Jul 24 2018, 17:51
nobbylon
nobbylon
Thanks Paul, I noticed the flats but thought the pod side was just cylindrical. I will look a little closer in the morning!
9Back to top Go down   K100Rs mirror fixing Empty Side mirror Mon Sep 10 2018, 08:59
monaro74
monaro74
Just before I took the bike off the road for some gearbox "I have no idea what I'm doing" work. I went for a ride and I noticed that the mirror was vibrating a lot. I reached in to touch it doing 80ks on a country road and the bugger just flew off.........I spent the next hour searching the long grass on the side off the road looking for it. Must of looked sus, some bikey looking guy walking in long grass staring at his feet. Two elderly ladies came over to see if they could help. Had a happy ending we found it, unbroken. Now I have to work out what parts are missing the put it back in......
10Back to top Go down   K100Rs mirror fixing Empty Re: K100Rs mirror fixing Mon Sep 10 2018, 10:10
Was it just the glass or the whole thing with the turn signal?  You can still get the clips that hold the mirror pod on the fairing.  They seem to lose their grip as they age(don't we all?) and new ones tighten things up nicely.  They are a bit pricey, but much less than a new mirror assembly.
11Back to top Go down   K100Rs mirror fixing Empty Re: K100Rs mirror fixing Tue Sep 11 2018, 02:38
Im still trying to work out how to remove the glass
Tried the slam down method no luck ( must be weak )
Tried the cable ties method ( chicken out )
One day will get the trim tool or see someone who has the skill
