DBRMN wrote:Oh but if you have terrible seals it has more chance of seeping through?
See my edited post just above.
My experience with this issue of oil leaks after using synth oils goes back to the '70s when synthetics were becoming popular, especially during the first and second energy crises.
I was a curious lad, prone to reading Popular Mechanics, Popular Science, Road & Track, Autoweek, of many other magazines in the school library and at home. In those pages the subject was much discussed. My motorbikes got regular oil changes using traditional oil, but they were newer, of mid to late '70s vintage. When I finally tried synthetic oil I had no such issues, until I put synth gear oil and synth engine oil into my 1970 R60/5 with about 40,000 miles on the clock. This time, after a while, I got seepage on the shift lever seal, and in the front crank seal. So I went in search of the reason. It turns out manufacturers, in the late '70s, had begun to use a larger quantity of Buna N elastomers mixed in to the seal stock (which had been around since the '30s, invented by IG Farber & company) which allows for a greater heat range in rubber, greater resistance to petroleums, and a longer life due to flexibility, etc. A 1970 BMW motorbike still had the brittle, older seals throughout. Over time I ended up replacing those seals with newer materials and lo and behold, only a worn shaft, that even a good seal wouldn't work well on, had any seepage.
So, in the 'early daze', and beyond, yes, there were some instances of leakage, but it was the rubber composition that was the issue. Synthetic oils simply highlighted where a product needed to be improved. I highly doubt there are any NOS (new old stock) seals of the old type that are viable forty years later even if kept in proper storage.
Imagine if one major industry, inherently reliant on another industry, was producing a product its partner could not use successfully?
Myths linger.
