1Back to top Go down   K100 or k1100 fog light Empty K100 or k1100 fog light Wed Aug 29, 2018 5:41 pm
TheJoker
TheJoker
Im sorry if I've posted this before don't remember doing so.
Purchased this a few months ago. I believe this was from a k1100 police bike however can't seem to find any examples.
As you can see it has a bmw plug on ao I believe this was an added extra.
Just wondering has anyone seen anything similar. If not can anyone advise on the best way to hook it up to the brake light.
K100 or k1100 fog light Fb_img10
K100 or k1100 fog light Fb_img11
2Back to top Go down   K100 or k1100 fog light Empty Re: K100 or k1100 fog light Thu Aug 30, 2018 2:22 am
that connector is almost the same as the clutch , rear brake switch  front brake switch  as it leaves the main loom  the mate for it  is on the end of the cable coming from the switches , I believe its a 2.1 mm pin plug required to fit that socket , but I haven't seen many available at all ..exactly the same
inside the rear cowl stop light lens assembly you will see small spade type connectors connecting to each of the globe holders .
I would break into the cables before reaching the globe assembly
there is a hole in the rear cowl upper right hand side ...which lets the cabling loom to gain access to the rear lens , you could drop a cable out through that hole , so its on the under side of the rear cowl ...easily allowing access to that connector there ...I guess. as its a routine part of changing tyres , to remove that rear flap- guard from the bike to let the wheel come out the back whilst on the centre stand.
possible a cable p clamp could hold that cable in place so it doesn't bind - collect the rear wheel whilst moving ???
hope that helps
3Back to top Go down   K100 or k1100 fog light Empty Re: K100 or k1100 fog light Thu Aug 30, 2018 1:29 pm
TheJoker wrote:Im sorry if I've posted this before don't remember doing so.
I certainly recognise the pictures...and a little digging and, yes, it was from your post back in Feb 18
https://www.k100-forum.com/t13385-k100-rear-light#158219
Dai gave some good advice in reply 12
Good to meet you briefly at KFest back in May, by the way. Your bike was instantly recognisable.
K100 or k1100 fog light Uk-log10 K100 or k1100 fog light Sco-lo15
                              Paul  K100 or k1100 fog light 905546712
4Back to top Go down   K100 or k1100 fog light Empty Re: K100 or k1100 fog light Thu Aug 30, 2018 6:03 pm
Did I? So I did!!! K100 or k1100 fog light 44271
