1 1985 k100RS won't start--fuel pump not activating properly Tue Sep 11, 2018 10:28 pm
jumpinjimmy
New day, new problem. When I turn on the key and hit the start button on my 1985 k100 RS, the fuel pump doesn't get primed so the bike won't start. I can make it work by running a wire from the + terminal on the battery to the left hand pin side of the 6th fuse. It will then start and run for a few seconds. I have checked voltage to the right pin side of the 6th fuse and it is getting voltage when I hit the start button, however, it's a quick jolt of power and my meter is only reading up to about 9-10 volts. It's hard to say if it's my volt meter that is reacting to slowly or whether or not there isn't actually enough voltage arriving to start the pump. I've put my finger on the fuel injection relay and it's definitely activating when I hit the start button.
Is it reasonable to think that perhaps the relay has dirty contact and isn't transmitting enough juice to start the pump?
Any other ideas??
Your help and thoughts are appreciated. Thanks in advance for responding.
PS. new pump was installed only two years ago.
Any other ideas??
