This "How to" guide is for pocket covers
Re keying a pocket cover to your ignition Key I_18210
but the principle of how the barrel works is the same for pannier locks albeit that those barrels use flat tangs instead of round pins.
Step 1:
Remove the lock retaining ring.....
Re keying a pocket cover to your ignition Key I_18410
Re keying a pocket cover to your ignition Key I_18510
How they work:
The Key pushes pins in the barrel of the lock up into columns inside the housing. An opposing set of pins is pushed  by tiny springs to resist them.
Once the meeting faces of the two sets of pins is aligned with the meeting faces of the housing and barrel the barrel can rotate with the key.
A second set of columns in the housing provides the "open" position and allows the key to be withdrawn at this position.
Step 2:
The pins that need to be adjusted are behind these plates....
Re keying a pocket cover to your ignition Key I_18610
Use a sharp punch to tap them forward far enough to get a grip with pliers then keep your thumb over it so the tiny springs don't fly as you ease the plate out:
Re keying a pocket cover to your ignition Key I_18710
Step 3 ....drill out the roll pin retaining the tongue: (1.5 mm drill bit)
Re keying a pocket cover to your ignition Key I_19110
Remove the barrel:
Re keying a pocket cover to your ignition Key I_19210
the internals look like this: ( Key is for scale)
Re keying a pocket cover to your ignition Key I_19010
With the barrel out push the key you want to use in and observe which pins are proud:
Re keying a pocket cover to your ignition Key I_19510
Note, in case they fall out, the pins in the barrel are pointed on the key side and flat on the side photographed. The flat face mates to the short pins pictured above.
The next step is to simply cut and/or file the pins (they are brass so soft enough) flush with the barrel. Any protrusion will stop the barrel from rotating in the housing.
Once you are satisfied the pins match the key, reassembly can begin.
Insert the small square pins first followed by the spring for each of the 4 key points:
( I find the best way to handle the springs is with a small jeweller's screwdriver inserted between coils.
Re keying a pocket cover to your ignition Key I_19610
Reinsert the plate, holding each spring down in turn until they are all properly home:
Re keying a pocket cover to your ignition Key I_19710
Reassembly of the rest is a straightforward matter. The roll pin may be reused if you were lucky with the drill otherwise a suitable small screw will replace it.
Test it vigorously at this stage and you my have to have a second go at filing the pins.
Once your are happy you can refit the lock and retaining ring
Re keying a pocket cover to your ignition Key Ir-log1188....May contain nuts!Re keying a pocket cover to your ignition Key Ir-log11
K75RTP - 1994
Thanks for this Will - the inability to lock the covers has always bugged me but the keys that operate them are either long gone...or the covers in place are not the originals - or both.
I'll give it a go this weekend and mark you out of 10 on your instructions. I must admit, I was amused by the narrative saying "use a sharp punch" and the associated pic of a plaster on one of your fingers!
Re keying a pocket cover to your ignition Key Uk-log10 Re keying a pocket cover to your ignition Key Sco-lo15
                              Paul  Re keying a pocket cover to your ignition Key 905546712
lol!   coincidence I assure you !  Embarassed
K75RTP - 1994
88 wrote:lol!   coincidence I assure you !  Embarassed
Re keying a pocket cover to your ignition Key 44271 Re keying a pocket cover to your ignition Key 44271 Re keying a pocket cover to your ignition Key 44271 Re keying a pocket cover to your ignition Key 44271 Re keying a pocket cover to your ignition Key 44271 Re keying a pocket cover to your ignition Key 44271 Re keying a pocket cover to your ignition Key 44271
A couple of years ago I tried something similar, however the small springs made a bid for freedom and disappeared completely. I now have a lock that any flat object can turn.
Paul: when you do your lock, can you measure the size of the springs and note them here because (Stan) you will be able to get new ones on the modelling sections of ebay. Been there, but not with the pocket lock.
Ah! I remember - I lost a GPI switch spring and ebay provided five for about AU$1.
Dai wrote:Paul: when you do your lock, can you measure the size of the springs and note them here because (Stan) you will be able to get new ones on the modelling sections of ebay. Been there, but not with the pocket lock.
...and the answer is the springs are 6mm long, in the uncompressed state.
There's 8 of the pesky little things - I found that they behaved quite well when dismantling the lock, but made a concerted bid for freedom when gently trying to compress them in order to slide the retain covers back into place over each group of 4. Not a job to be done in a messy workshop with no end of spidery corners for them to hide.
Anyway, the good news is that Will gets a 10 out of 10 for his "How to". It's a fiddly little job and getting that roll pin out takes a little patience.
In the end, I found that only 1 of the 4 on my two LTs needed re-keying and I was able to do this successfully. However, both my left side covers (the bulbous radio style cover) can still be opened easily, even when locked, without needing anything inserted in the lock at all...so those locks are pretty pointless. The right hand side (flat covers) both seem to lock reasonably securely - well, securely enough to stop casual thieving little fingers chancing it, but I wouldn't leave anything of any value in the pockets as I don't think it would take more than a split second with a screwdriver or similar the lever to pop them open.
I have 2 spare covers from my donor bike - both are in the locked position, which prevents access to the securing ring screw to allow removal of the lock mechanism from the cover. They probably could be re-keyed in situ, but I'll see if I can find the donor bike keys and see if they work first.
Paul,
you could try some other keys as well. Some years ago Blakey and I went around the assembled bikes at one of our gatherings and between our two keys we could open/start 80% of the bikes. Keys and locks wear and you never know, you can get lucky. The only lock on my 83 basic that is precious is the steering lock which will not accept the fold down key, but will take the long solid key.
88 post has been converted to a PDF and stored on the kforum-tech server.
Download it from this site.
Re keying a pocket cover to your ignition Key Frog15Re keying a pocket cover to your ignition Key Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
great " how to " Will
thanks for the time and effort
