1 Re-wiring K100RS Tue Aug 28, 2018 6:04 pm
GF Wollongong
Am SLOWLY going through my K100RS 1984 and cleaning up the electrics.
A couple of little questions:
Fan wiring: from fan to first connector is violet/yellow and brown wires. Violet/yellow is fraying. Brown has broken at the clip and male 3mm spade connector is gone.
Q: Has anyone worked out a cheap source of wiring to match the variety of coloured wires on (our) bikes? I would like to replace with same colouring. Am thinking go to a wrecker's yard and get a wiring loom from a car.
Q: where to get some connectors of this small size?
In both cases, Jaycar does not have the right bits. I know I could bodge it up ... will if I can't find a correct alternative.
Have been squinting at the Clymer wiring diagram. It was only after I got a A3 enlargement of it that I could finally read it. What a difference
And while I'm here...confirmation sought
Found a single brown/green wire broken off at small white connector. Same type of male connector as above. Joins under the RHS of fuel tank. The other end heads down to the Hall Effect Sensor and further along into the LHS front of the engine. I assume it is the oil pressure sensor. It looked important but had no effect on the bike's running previously.
Guy
Guy
