1Back to top Go down   Brand new Fuel pump not working Empty Brand new Fuel pump not working Mon Jan 07, 2019 10:49 pm
JDiggamus
JDiggamus
Hello All,  Need some help here, I'm a novice.  I just bought a 1984 K100rs, the fuel pump was bad, at least so I was told, so I bought a new one and replaced it. However, nothing happens to the pump when I try turning the bike over.  Disclaimer, I haven't turned the bike on yet since I got it 5 days ago, been waiting on the fuel pump.  I haven't really checked anything other than the fuses and there are 2 fuses missing from the slots.  Anyone know what kind of fuses I need?
If its not a fuse problem what could it be?
thanks for your help in advance, I'm learning as I go.
2Back to top Go down   Brand new Fuel pump not working Empty Re: Brand new Fuel pump not working Mon Jan 07, 2019 11:07 pm
Fuel pump fuse is # 6 from the top marked Kraffstoppe. The 4 pin connector that resides under the RH side of the fuel tank is a known source of problems. Cleaning with 2 part DeoxIT can sometimes restore connectivity. Once mine started to play up I cleaned it a couple of times then replaced it. I replaced it with a waterproof one from an electronics store. With the connector apart check for power when you hit the starter button.
3Back to top Go down   Brand new Fuel pump not working Empty Re: Brand new Fuel pump not working Tue Jan 08, 2019 3:29 am
Also: fuse #4 has a 12-volt feed on one side but isn't connected to anything.
4Back to top Go down   Brand new Fuel pump not working Empty Re: Brand new Fuel pump not working Tue Jan 08, 2019 3:43 am
On 84 K the fuel pump plug connector is the front left of the tank and is even worse for trouble.
If you probe into the pins on the plug you can open them out a little to make a better connection with the receiver under the tank.
5Back to top Go down   Brand new Fuel pump not working Empty Re: Brand new Fuel pump not working Tue Jan 08, 2019 5:22 am
I'm curious how you have an '84 K in the US. Is it a Euro model, or perhaps a build date of late 1984 which might make it an '85? The US didnt get K bikes until model year '85. Please post the last seven digits of the VIN as your signature so we know that we are looking at apples not tangerines.
Go to:
http://www.realoem.com - enter the BMW catalogue, then your VIN to see the model year, production date and intended market.
6Back to top Go down   Brand new Fuel pump not working Empty Re: Brand new Fuel pump not working Tue Jan 08, 2019 6:46 am
Please supply photos when describing problems. It is a help to respondents. Which fuses are missing?
Brand new Fuel pump not working K100_f10
7Back to top Go down   Brand new Fuel pump not working Empty Re: Brand new Fuel pump not working Tue Jan 08, 2019 6:53 am
First order of business is to make sure that the fuel pump is good.  Put 12V to the smaller diameter terminal and ground to the other terminal.
8Back to top Go down   Brand new Fuel pump not working Empty Re: Brand new Fuel pump not working Tue Jan 08, 2019 10:34 pm
JDiggamus
JDiggamus
Two Wheels Better wrote:I'm curious how you have an '84 K in the US. Is it a Euro model, or perhaps a build date of late 1984 which might make it an '85? The US didnt get K bikes until model year '85. Please post the last seven digits of the VIN as your signature so we know that we are looking at apples not tangerines.
Go to:
Model K100rs
Production mo/yr- 08/1984
the intended market was Europe.
I got this beauty in Long Beach, CA
9Back to top Go down   Brand new Fuel pump not working Empty Problem Solved! Tue Jan 08, 2019 10:39 pm
JDiggamus
JDiggamus
Thanks for all the advice people, in the end, it was the 4 pin connector that was faulty.  I also replaced all the fuses for good measure. The fuel pump is running.  thanks again!
