1 HELP!!! Engine Flooding on Startup Fri Aug 10, 2018 9:32 am
GB777
Twelve months ago I purchased a '90 K100RS 16V with 175,000km on clock that was screaming out for a restoration. Although the bike was in poor condition cosmetically, the engine was in great condition, very quiet, smooth and very easy to start hot or cold. The restoration is now finished and the bike looks fantastic but during the restoration the engine wasn't started for about 3 or 4 months and when i tried to start it it was flooding with too much fuel. I could get the engine to start by giving it lots of throttle while cranking the engine over and when it started it was not running on all cylinders and had lots of light coloured smoke (not blue) coming out of the exhaust and stunk of fuel.
I checked the plug leads.
Changed the spark plugs.
Replaced one coil that appeared to be a bit sus.
Cleaned all connections on bike (including ECU) with contact cleaner.
Dosed the near empty fuel tank with a full bottle of Injector Clean.
Tried starting with the Throttle Position Switch disconnected (no difference).
Managed to get the bike started and held it on 2000rpm until the smoke cleared and started to run smooth which took about 8 mins. When the revs were dropped it started to flood again. The next day it started a lot easier so I took it for a ride and it quite well until I restarted the bike after a 15 minute spell. It flooded again although nowhere as bad as previously and cleared very quickly, so it appeared the Injector Clean treatment was working. I refilled the tank on the way home. Later that day when the engine cooled down I tried to start the engine and it started perfectly. I rode the bike to work for the next four days without any problems, then it all started again.
I fitted the injectors out of my K1100RS.
Fitted new Fuel Pressure Regulator (FPR).
Replaced a dodgy vacuum hose going to the FPR.
On first attempt to start engine with no throttle, the engine would start and idle at very low revs (about 400rpm) and any attempt to increase revs resulted in the engine stopping, then it was back to needing lots of throttle when trying to start the engine followed by lots of smoke and smell of fuel again. I removed the plugs and they were very wet with fuel.
I'm running out of ideas and thinking that the ECU may be faulty. If anyone has some suggestions I would be extremely grateful.
Last edited by GB777 on Fri Aug 10, 2018 9:35 am; edited 1 time in total (Reason for editing : One detail was added.)
Gary
'94 K1100RS Mystic Red
•Dyno Tuned to deliver 115 bhp. •Audiovox CCS-100 Vacuum Cruise Control. •Fuel Plus Version 3.1 Trip Computer. •R1200c Final Drive Gears (32/13 or 2.54). •Ohlins rear shocky. •K100 complete Aluminium Radiator fitted. •Davies Craig Thermo Switch fitted to Cooling Fan with manual over-ride. •Fuel Cap drilled and tapped to provide mounting points for accessories, including mini Tank Bag & Apple CarPlay Screen •HID Hi-Lo Headlight and every other incandescent bulb on bike replaced with LED's. •Bulb monitoring warning light no longer needed so it's now used to indicate when Side Stand is down. •LED (Halo) Front Park Light (BMW Car style).
