1Back to top Go down   Removing The Bottom Half? Empty Removing The Bottom Half? Mon Jul 30, 2018 1:59 pm
blueeyedogre
blueeyedogre
Does anyone run their K100RT without the bottom half of the fairing? At 6'3 I find my knee hits it and wounding about doing away with it.
2Back to top Go down   Removing The Bottom Half? Empty Re: Removing The Bottom Half? Mon Jul 30, 2018 3:45 pm
No problem to do it. I have left the bottom parts off while doing maintenance. Just make sure the top part is fully mounted on its brackets. You probably should remove the radiator surround as well as its supported in part by the two lower fairing panels.
3Back to top Go down   Removing The Bottom Half? Empty Re: Removing The Bottom Half? Mon Jul 30, 2018 3:59 pm
yes , have the same issue, as do many
what seat do you have ? hope fully the comfort seat ?
but if leaving the bottoms off , please look at strengthening the lower fairing mounts that mount on the down tubes behind the radiator
the original  weak brackets do flex without the support of the lower fairings, so if it can be done  do it , or at least double up those brackets
cutting away some of the heat shield plastic between the uppers and tank at the rear end also helps .but don't forget to install some decent insulating rubber surround stuff to eliminate any sharp edges
good luck
