Go to page : Previous  1, 2
Last summer three of us did the Paul Bellthorpe memorial motocross ride on a really hot day. The Bricks got a real workout on what is a vey hilly rough four wheel drive track. Both Paul and Mick complained of excessive tank temperature while mine was still comfortable. After running the heat shield for 2 years with no more overheating problems, I decided to build a Mk 2 version to fix a inherent problem with the Mk1 version.
While the Mk1 version cured the overheating problems, it added a couple of problems. In order to balance the throttle bodies/idle adjust the fuel rail with injectors has to removed and the heat shield removed. You then have to refit the rail/injectors and balance the throttle bodies, and then remove the rail and refit the heat shield.
At the moment I'm in the process of doing a modified heat shield that is in two pieces the bottom part slides under the rail and the top half screws onto the tabs on the bottom half via Nutserts. While the bottom part of the shield will still be fixed the top half will be removable allowing access for maintenance. If it works I'll post some pictures, it's in a design as you build stage at the moment.
Regards Martin
Pictures of the Mk 2 version at this stage. The Mk1 was made using .6mm aluminium the Mk2 uses 1.5mm aluminium. It just requires the mounting tabs to be shortened and a bit of filing, polishing and cutting the foam insulation to fit. I've decided to bolt the two parts together with three 4mm bolts into Nutserts. Hopefully I'll finish it and mount it early next week.
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 P7230110
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 P7230111
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 P7230112
Last edited by MartinW on Wed Jul 22, 2020 7:34 pm; edited 1 time in total (Reason for editing : Added dimensions)
StandardK
StandardK
Patent Pending I hope...ingenious
Regards
Dan
jcd06
jcd06
Nice craftmanship Martin.
This is a picture of my solution.
The insulation prevents the fuel hose to get heated by the air coming from the radiator.
It worked well in 40 degrees ambient, driving about 80km/h. I can't tell what it does in traffic jams.
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 P2050010
* Train dogs. Teach people.
Because of the heat sitting in traffic in Queensland summers I had to go a bit further. All under tank lines have been insulated with tight fitting thick foam insulation. The under side of the tank has been fitted with double sided reflective insulation. The Mk 1 version worked well and greatly reduced fuel temperature, so the Mk 2 version should hopefully work just as well.
a good idea martin
hope it works out ok
Thanks Charlie hopefully, maybe, possibly fitted by Monday. Too many projects not enough time, I should never of retired.Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 610153
yeah i feel your sorrow and understand the "no time" issue
started another hair brained project myself , when a motor (broken ) and a frame (also in bad need of a LOT of TLC ) came my way for the right price care of Smithy and a local mate Alex
just came to mind to explore a lot of the back roads that im unwilling to take Gerty down too far
still to fix the motor but thats in hand but an awful lot of time spent on eliminating rust all over the frame and parts , the previous owners must have had a ball playing with it  before retiring it with a run out of oil (several times ) event , then parked it out in the weather for years
just a taste of the progress
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 20200610
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 20200711
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 20200712
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 112350 Wow a blast from the past, and looking good. I have a soft spot for Suzie  two strokes, I raced TS125 Duster fitted with a OEM Suzuki  motocross kit in the early 70's. Followed by a TS 185 Sierra for trail riding. The DR's were pretty bullet proof, how many cc's? Beside Paul and Matt leading us astray I am trying to avoid dirt these days, although the Bricks do seem to cope well.
Stay safe regards Martin.
Yaaay finished and mounted. I didn't own or desire to purchase a Nutsert gun for three Nutserts so I used the bolt and slightly oversize nut method to attach the Nutserts. A bit of fettling was needed, but the unit assembled easier than the Mk 1 version. I didn't have to trim the insulation around the injector clips due to a tighter fit around the injector mounting cups. The whole unit was assembled on the bench greased with a bit of silicone grease on the "O" rings and it slid easily into place and bolted up with no problems. A slight bend had to be put on the lower shield to clear the injector electrical connectors and a corresponding bend placed in the top shield. The top shield was fitted with a piece of the doubled sided insulation glued to the back, and it was attached to the lower shield with non stainless steel  Allen bolts, which will be upgraded. Access to the idle screw and throttle bodies is now not a problem.
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 P7270116
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 P7270117
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 P7270118
DadofHedgehog
DadofHedgehog
MartinW wrote:Yaaay finished and mounted. I didn't own or desire to purchase a Nutsert gun for three Nutserts so I used the bolt and slightly oversize nut method to attach the Nutserts. A bit of fettling was needed, but the unit assembled easier than the Mk 1 version. I didn't have to trim the insulation around the injector clips due to a tighter fit around the injector mounting cups. The whole unit was assembled on the bench greased with a bit of silicone grease on the "O" rings and it slid easily into place and bolted up with no problems. A slight bend had to be put on the lower shield to clear the injector electrical connectors and a corresponding bend placed in the top shield. The top shield was fitted with a piece of the doubled sided insulation glued to the back, and it was attached to the lower shield with non stainless steel  Allen bolts, which will be upgraded. Access to the idle screw and throttle bodies is now not a problem.
Following with interest. A propos of nothing at all, I seem to recall that water (liquid) cools 17,8 times better than air. This factoid implies that cooling the liquid components, if achievable, will lower overall system temperatures much more than cooling the air circulating around the system's surfaces.
PRESENT:
1995 K75T.  I am the 3d owner.  Bought it in June 2019 with 6,242 miles on the odo.
1991 K100RS 4-valve attached to a 1990 Flexit sidecar. I am at least the 3d owner. Bought with 21,00+ miles on bike's odo.
PAST:
old (indeterminate age) Ural + sidecar
1997 Buell S3T Thunderbolt
1982 BMW R100CS
1974 Kawasaki KZ400
1970 Suzuki Titan
Dadof the MK1 did all the things that I wanted to achieve plus some. It no longer stalls on hot days in traffic, which was the goal I was aiming for. Secondly the tank temperature has been brought down a comfortable level which was a bonus. The aim of the Mk 2 version has now solved the maintenance access issues. And due to reduction of gaps in the insulation and the  aluminium thickness which has over doubled from .6mm to 1.5mm it should in theory insulate the rail a bit better. Unfortunately temperature testing will have to wait till summer as it is still winter here and we are experiencing a cold spell of 21C today. Also a side benefit of the new design it will allow me to experiment with reducing the height of the top part of the shield from it's height of 60mm down to various other heights.
Regards Martin
MartinW wrote:we are experiencing a cold spell of 21C today.
You had to say that, didn't you? We're damn lucky if it ever gets that high even in mid summer!!!
Unfortunately we have rather a tough time in winter. But we don't complain and soldier on through it all, stiff upper lip and all that. Blizzard
gabriel
MartinW wrote:Bob I used a laser temperature gun to determine the temperature of the tank and the fuel rail. I determined that the fuel was getting too hot when it would stall and die in traffic on 30C+ days to the point where it was dangerous and I nearly got rear ended, multiple times. The temporary cure was to run with a full tank of fuel which stopped the fuel from overheating or avoid traffic on 30C+ days. 30C + days on the main roads were never a problem.
Hi Martin
Is it possible your engine is overheating due to a faulty fan. Please check your fan and actually see it functioning correctly.
I appreciate the effort that’s gone into your solution, but wonder how much of an issue it is.
Take care.
Gabriel
;BMW; 1984 BMW k100..frame number 6228?
1992 BMW K75s
Gabriel the engine cooling is fine, the fan comes on when it's supposed to and I have an override switch fitted. I've never had a problem with coolant overheating. What happens in my case was fuel vaporization caused by heat build up on hot 30C plus days in traffic. After sitting at lights you'd go to take off and the engine would cough splutter and stall, or nearly stall. The cars behind you would be expecting you to take off and as a result of the stalling nearly rear end you.This would only occur at around 2/3 empty, the solution at the time was to run a full tank of fuel.
Other Brick riders have suffered a variation in that the tank would become unbearably hot to touch. Quite a few members have fitted inline fuel coolers to alleviate the problem. I tried a fuel cooler but it only worked at speed didn't work in traffic. I'm a member of a local Trades Guild and one of the members is a heat engineer and after discussing the problem with him I came up with another idea. Rather than trying to get rid of the heat after the fact, don't let the fuel heat up in the first place. I ran the first heat shield for 2 years and it solved the stalling problem, and it also greatly reduced the tank temperature. The Mk 2 version now allows access for tuning.
BMW acknowledged that there was a problem and removed baffles from some bikes and insulated the fuel rails in others. If you have a Haynes Manual it is covered in the book under fuel and lubrication 6.9 part 13 titled Tank insulation. As stated all my fuel lines are insulated as well as the under tank. I've used a laser thermometer to record temperatures and the shield has reduced the rail and tank temperatures by more than half.
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 Fuel_t10
Packo
Packo
I think we all agree that fuel overheating in the K series is an issue.
This is the way I "overcame" the problem, but before I go any further I must say I have not taken any temperature readings, but I do think that the tank is noticeably cooler on hot days.
I inserted a "T" piece in the line from the tank to the fuel rail
One line then from the T to the fuel rail
One line then from the T to the FPR
Blanked off the other end of the fuel rail
Theory being that most of the fuel will circulate from the tank thru the FPR back into the tank, the engine using only what is required out of the fuel rail. In conjunction with other methods like insulating fuel lines and tanks etc further cooling should be able to be achieved.
I have had this in place for 3 years now and seems to work ok but as stated previously I have no figures to back it up. I am not going to put it back to original to take temp readings but would be interested to hear findings if someone else could be bothered.
Sorry Martin , not trying to hijack your thread
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
DadofHedgehog
DadofHedgehog
Packo wrote:I think we all agree that fuel overheating in the K series is an issue.
That's pretty neat.
PRESENT:
PAST:
1982 BMW R100CS
1974 Kawasaki KZ400
1970 Suzuki Titan
There are a Kluster of us going for a four day ride so I'll get some temperature comparisons. But the real test will be in summer in traffic. I had a few spare 3D printed 75s badges in blue. I couldn't help myself so painted one black and mounted it on the upper shield to break it up. I need to get some more 1.5mm aluminium to make a couple of different height top shields to see if that makes any difference and I also want to paint one shield black.
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 Mk2_he10
Our 4 day Kurfari gave me the opportunity to get some readings between a few different bikes. Readings of 4 bricks at one of our early stops gave the following rail temperatures 2 RS's rail 80 C a K100 standard also 80 C which I thought would be lower, my 75s 35 C. The reading remained pretty well consistent throughout the trip, two RS's 80 C to the 75's 40C which did include some spirited riding. I've just finished doing a colour change and I'll see if it makes any difference.
Regards Martin.Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 P9070210
Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 P9070211
KlaustheK
KlaustheK
Has cooling the fuel rail led to any changes in fuel consumption, or noticeably increased performance? Cool fuel was and old drag racers trick to go faster.
1987 K100RS Klaus *sold*
1989 K100RS SE Klaus 2 *sold*
1997 K1100LT Gunter
Seat of pants Dyno says yes on performance improvement as the acceleration lag on hot days is gone. In general it seems to go a bit better. However unless I could do a Dyno comparison it's hard to substantiate. The way the guys ride doesn't make fuel mileage testing practical.
What about the heat of the tank any cooler  ?
I know mines get hot  on the inner leg
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
Matt on the SSD Bell Thorpe motocross adventure ride both Mick and SSD complained about hot tanks. Mine was fine even though the tank is black.  We had a mini workshop today fixed my clunk fixed Micks centre stand and fixed SSD's loose 22 Lt top box. Overheating Fuel Solution Mk1 & New Improved Mk2. - Page 2 723598
