1Back to top Go down   freeze plugs Empty freeze plugs Sun Jul 08 2018, 20:09
mjbtdi
mjbtdi
Thought i was on the home straight restoring a 1986 k100, just finished transplanting a final drive and resealing the oil pan. Fired it up...... and coolant starts to pee out a pin hole in one of the freeze plugs, between cyl 1 and 2!
Quick search of as cycles site and no joy, anyone have a recomendation on where to get replacements, dealer will be my last resort when they open tuesday.
As always your help is greatly appreciated.
Mike
2Back to top Go down   freeze plugs Empty Re: freeze plugs Sun Jul 08 2018, 20:45
mjbtdi wrote:Fired it up...... and coolant starts to pee out a pin hole in one of the freeze plugs, between cyl 1 and 2!
What size is it, Mike—22mm? Could you post a photo of the leak?
3Back to top Go down   freeze plugs Empty Yes 22mm Sun Jul 08 2018, 21:45
mjbtdi
mjbtdi
yess 22mm, tried and failed to post pic from my phone!
4Back to top Go down   freeze plugs Empty Re: freeze plugs Mon Jul 09 2018, 00:08
mjbtdi wrote:yess 22mm, tried and failed to post pic from my phone!
Keep trying! It's got to be less messy than replacing the plug. Smile BMW 11121733403
5Back to top Go down   freeze plugs Empty Re: freeze plugs Mon Jul 09 2018, 00:33
You will need to replace all the plugs, if one has gone the others aren't far behind it.
6Back to top Go down   freeze plugs Empty Re: freeze plugs Mon Jul 09 2018, 00:44
mjbtdi
mjbtdi
Yes will need to do them all, i pulled the old plug out and its not pretty, a shame the clymer manual does point out the need to replace as a set but doesnt give you the sizes.
I ordered a box of 22mm ones from amazon, but will have to get the calipers out to size the other ones.
