1Back to top Go down   LED headlight replacement  Empty LED headlight replacement Sun Jul 01, 2018 4:06 am
MarcS
MarcS
I live in a rural area and frequently need to dodge kangaroos and live stock at night. The 7" round aftermarket light on my K seems reasonable but has anyone tried these
https://www.ebay.com.au/itm/H4-7Inch-200W-CREE-LED-Driving-Light-Headlight-Lamp-Kit-Round-For-Jeep-Wrangler/252428320874?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
In the past I have tried various led/hid kit replacement bulbs but nothing really cut it. I do plan to fit the relays the everyone recommends to get the load off of my switch but maybe these are better????
K100rt ex plod bike 5/1990.
I have no problem with authority. Just some of the morons that are paid to enforce it.
2Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Sun Jul 01, 2018 4:20 am
3Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Sun Jul 01, 2018 9:28 am
BobT
BobT
Would be very interested in your findings should you go for that headlight Marc. Only thing that would put me off is the claims of 200 watt, that would be a lot of power consumption for an LED, and watts are not a measurement of light (lumen). Makes me think that the seller doesn't know what he is talking about.
I have also tried many LED bulbs and they just don't work unless fitted to projector headlights, even then they do not seem to match the light output of a halogen.
4Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Sun Jul 01, 2018 11:21 am
BobT wrote:claims of 200 watt, that would be a lot of power consumption for an LED,
That doesn't sound right to me either.
It's also an unbranded product.
5Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Sun Jul 01, 2018 12:03 pm
duck wrote:It's also an unbranded product.
Back door QA failure. Betcha. bounce bounce
6Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Mon Jul 02, 2018 12:54 am
MarcS
MarcS
7Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Mon Jul 02, 2018 2:00 am
You may have unwittingly found a good connector for the pre 85 type tank. Anybody out there care to order one to find out. I would do it but haven't got a pre 85 tank.
8Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Mon Jul 02, 2018 2:24 am
BobT wrote:Would be very interested in your findings should you go for that headlight Marc. Only thing that would put me off is the claims of 200 watt, that would be a lot of power consumption for an LED, and watts are not a measurement of light (lumen). Makes me think that the seller doesn't know what he is talking about.
I also tried LED bulbs........rubbish.
9Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Mon Jul 02, 2018 3:25 am
92KK 84WW Olaf wrote:I also tried LED bulbs........rubbish.
Lots of crap has been put out over the years but they're actually making progress on them these days. I have all of my bikes upgraded to high power halogen but if and when I get another K I may try one of the newer H4 LED bulbs. They're not cheap though. I think decent ones run about $80 in the US.
10Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Mon Jul 02, 2018 7:32 am
RicK G wrote:You may have unwittingly found a good connector for the pre 85 type tank. Anybody out there care to order one to find out. I would do it but haven't got a pre 85 tank.
I will mate I have a couple of pre 85 tanks
KKlompy LED headlight replacement  2854237993
LED headlight replacement  Au-log10
11Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Mon Jul 02, 2018 10:26 am
I recently bought some h4 led head lights , (but used in the tin box so far)
of corse the Chinese cheat  you may find that the total light output of 2 globes is the equivalent of 2 x 100 watt poorly designed incandescent globes   and could well be only 40 - 45 real watts or so for each globe but rated in some weird Chinese version of lumen output for the leds .
I must say the light output (that I purchased for not much money at all)  is very impressive  with 2 of 3 elements active on low beam  lets say 30 watts of power going in each side for low beam ...the high beam is the third element active as well  and I would guess another 15  watts of led lighting making 45 watts total for each globe …  the light on the road is amazing just on low beam  .
the issue I have is it requires realigning the beam to a lower angle as the spread of light is quite high relatively to the horizon ...id say suffering from a wider element of light (a bit like the corona of hid type lights with the full globe acting as the light source rather than the halogen filament  only ) affecting the focus .
the linked report is quite interesting and I  will wait to see if the manufacturing process spreads ( as is the usual norm in china) as they rip off the process developed by others .
what I bought
LED headlight replacement  20180713
what it looks like on low beam ...very impressive in comparison to halogen Plus 50 s
LED headlight replacement  20180714
we could see, quite soon, amazing results for not much money at all .
12Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Mon Jul 02, 2018 12:46 pm
BobT
BobT
As can be seen from Charlies post above, LED bulbs do not work in standard reflector headlights as the beam cut off is completely destroyed.
To maintain the correct beam pattern requires a halogen filament, that puts out light in every direction, 360 degrees, to be in exactly the correct place in the reflector. No LED meets these needs so you lose your cut off and stray light ends up everywhere. With that stray light being whiter than a halogen, people believe that there is more or better light.
There is no such thing now as a high power halogen as halogen has reached the peak of its development. People think that a 100 watt halogen has 90% more light as a 55 watt standard, it has not, it has about 10 to 20% more light and 90% more heat!
13Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Mon Jul 02, 2018 3:30 pm
MarcS wrote:I live in a rural area and frequently need to dodge kangaroos and live stock at night.
In the US we have deer whistles to keep deer from jumping out in front of US. Do they sell roo whistles in OZ?
14Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Mon Jul 02, 2018 4:46 pm
The only deer I've ever hit was when I was driving my car home from work at midnight 20 years ago. The deer bounced off the right fender and bounded into the woods. The only damage was its impact broke  the deer whistle mounted on that side. I haven't invested in one since then. Smile
15Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Mon Jul 02, 2018 9:36 pm
Several products available including one called Shu Roo. No personal experience of their effectiveness but some swear by them.
16Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Tue Jul 03, 2018 12:09 am
I've never had Shu Roos and never hit anything besides suicidal birds. I have however run over a Roo's tail. He came out of the dark and propped fair smack on the white line and just looked at me. I had two choices stay on the right side of the road and go in front of him. Or go on the wrong side of the road and go behind him. At the last minute I crossed the line and ran over his tail. Roo's can't jump backwards. Shu Roo's work up until you hit one.
17Back to top Go down   LED headlight replacement  Empty LED headlight replacement Tue Jul 03, 2018 12:46 am
I have ordered the 4 pin connector for my K100. At $3.45 one cannot go far wrong. I'll let you know how it goes. Cheers Tom
18Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Tue Jul 03, 2018 2:15 am
Those Roo whistles are about as usefull as tits on a lizard. Roos have the same hearing characteristics of humans. That is they don't hear any noise  above 20000hz and at anything above about 30kph the whistle is above 20000hz so the roo cant hear it.
I have tried this out on roos in my front yard and when I blow through the whistler the rood will stand up and look about but only if I can hear the whistle and if I blow hard enough for the whistle to be out of my hearing range the roos don't react because they don't hear it.
but if you are in the habit of taking the dog in the car/sidecar it will drive them crazy.
19Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Tue Jul 03, 2018 3:53 am
MarcS
MarcS
I had them on my pilot/escort vehicles when I worked out in the desert. I believe that the roos do hear them. I used to see them look around and see the car coming. They seemed to catch their attention and give them an early warning to your approach. There was no startled jumping, just inquisitive looks. I will put them on the K but there is no substitute for being able to see them.
20Back to top Go down   LED headlight replacement  Empty Re: LED headlight replacement Tue Jul 03, 2018 2:03 pm
BobT
BobT
If you want to see direct comparisons of LED, halogen and HID xenon, then I have done a blog post. I used ny Ducati for the experiments as it is a single filament H11 bulb. The light output cannot be seen from the photos as the camera compensates for that, but the LED is the least light, the halogen about 50% brighter and the HID kit about 300% brighter than the halogen.
I would not want to use anything other than a halogen in a twin filament H4 bulb.
https://wp.me/p5xJlR-94
