1 1996 K1100LT Fork Woes Sat Jun 16, 2018 7:14 pm
brickrider2
It wasn't long before I got in over my head when I attempted to renew the oil seals on the K1100LT forks.
I removed the bolt on the bottom of the slider, which presumably frees the cartridge/rod/spring assembly. When I pull the slider from the tube, it stops suddenly with a metallic clank. It's not clear what is preventing the two pieces from separating, but I'm not optimistic that this will end well.
Any ideas of what my next step should be?
