1Back to top Go down   custom carbon fiber Empty custom carbon fiber Thu Jun 14, 2018 3:38 pm
mister_anger
mister_anger
hey,
Don't know if anyone has done this but just wanted share that it is possible to replicate some K100 parts in carbon fiber.
The battery cover is not done yet.
custom carbon fiber Img_2011
custom carbon fiber Img_2012
custom carbon fiber Img_2010just wanted to share
2Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Thu Jun 14, 2018 5:00 pm
Very cool!! custom carbon fiber 502531
3Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Thu Jun 14, 2018 5:21 pm
Nice! custom carbon fiber 212902
4Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Thu Jun 14, 2018 9:51 pm
Woodie
Woodie
Very nice!  Now I want them.  How do I do this?  Very Happy
custom carbon fiber Logo2111
1985 K100RT  52667
1990 K75RT 6018570 (project)
5Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Thu Jun 14, 2018 11:01 pm
brickrider2
brickrider2
Lovely!  Fitting those is a very nice way to tart-up a K-bike.  Good work.  cheers
6Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Fri Jun 15, 2018 3:31 am
mister_anger
mister_anger
Woodie wrote:Very nice!  Now I want them.  How do I do this?  Very Happy
there are probably more ways to do this but this is how I did it :
- take the original part and put PVA on the outside. this prevents the expoxy resin of sticking to the plastic.
- then put 2 layers of carbon fiber with epoxy resin on the outside of the part.
- pull of the plastic part and add 2 or 3 layers of glass fiber to the inside of the part to reinforce it. I did this using a vacuum bag so that i was sure that there were no air bubbles in between the layers.
- then add 2 layers of ultra clear epoxy resin (without any kind of fiber) to the outside so that when this is cured you can sand then down to get a smooth surface that you can buff.
remember to sand in between different steps wit a 280 grid. When you add the resin the 280 grid marks go away.
Basically it is a way of working backwards then the standard way of making carbon fiber parts but it  works.
The carbon fiber part will be +/- 0.3 mm bigger then the original parts because you add 2 layers of carbon fiber to the outside but fitting wise this is not an issue.
grz,M
7Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Fri Jun 15, 2018 5:33 am
BobT
BobT
You can buy stick on carbon that looks like it is real. There is no point in trying to save weight by using the real thing as the K will still weigh the same as a baby elephant afterwards.
8Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Fri Jun 15, 2018 7:37 am
mister_anger
mister_anger
BobT wrote:You can buy stick on carbon that looks like it is real. There is no point in trying to save weight by using the real thing as the K will still weigh the same as a baby elephant afterwards.
stick on carbon on a flat surface is easy but on parts like the battery cover are not so easy to get right.
I also don't think this stick on carbon will stay on for ever, nothing beats the real thing.
I am not doing it to save weight but more for the look of it.
9Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Fri Jun 15, 2018 7:50 am
BobT
BobT
https://www.youtube.com/watch?v=cnYHU7sDRyo
https://www.youtube.com/watch?v=oMSaPzoohHY
There you go, easy.
10Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Fri Jun 15, 2018 3:35 pm
mister_anger
mister_anger
This topic is intended for people who want to use carbon fiber not compare carbon fiber with stickers. If you want to use stickers then please do so.
11Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Fri Jun 15, 2018 3:40 pm
BobT
BobT
mister_anger wrote:This topic is intended for people who want to use carbon fiber not compare carbon fiber with stickers. If you want to use stickers then please do so.
This thread is on an open K bike forum where anyone who is a member can discuss anything. It would be unfair for others not to know what else that they can do to achieve the same look, after all you said yourself "I am not doing it to save weight but more for the look of it."
12Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Fri Jun 15, 2018 5:46 pm
mister_anger
mister_anger
You will not achieve the same look, not even close.
13Back to top Go down   custom carbon fiber Empty Re: custom carbon fiber Fri Jun 15, 2018 6:08 pm
BobT
BobT
mister_anger wrote:You will not achieve the same look, not even close.
Sounds like you are selling something.
