Fitting additional fuse box Mon Jun 18, 2018 7:18 am
Packo
![Packo](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![Silver member Silver member](https://i.servimg.com/u/f80/11/71/56/74/bmw-2s10.gif)
I find wiring diagrams very challenging along with most electronic stuff
I am fitting a sidecar on the above bike
To this end I want fit another fuse box in the sidecar to run an auxiliary fuel pump and USB charging port etc
The power for the fuel pump will be put through a relay (advice from a friend)
Does anyone see an issue if the source for the power to the sidecar is taken out of the Ignition switch plug under the bike tank,(the big orange plug). I have selected the green wire
Please advise if this is not a good idea or feel free to provide alternative solution as long as they are simple and easy to follow
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
