Number of posts : 7953
At the brake pedal you will see a rubber boot on the end of the master cylinder.
There is a movable receiver inside that boot for the end of the brake pedal pin. Check that it is properly seated, if not the pedal pushes it to one side and does not force the piston into the master cylinder to operate the brake. Also take the plastic cover off the caliper and check the pads move freely on the pins.
The pads and pistons do retract slightly when you release the pedal.
1971 Yamaha 125 YAS-1
