1 Fuel Light not working Tue May 15, 2018 2:44 am
George_Pap
Hey all. My K100RT resurrection project reached a 75% of success. I m really happy, a bit more poor but happy
Rode it for about 600km and it gets better and better. So far.
My challenge now is to get fuel lamp to lit.
The story
My bike had the early instrument with the 7 screws and the 7L + 4L lamps. It also has as you can guess the early fuel sender ( electronic stick )
When received the bike 7L and 4L were working properly.
Due to a short circuit that destroyed the green plug and the ribbon pcb bellow it I had to replace the instrument cluster though with an 1987 K75 one. The one with round pins and unfortunately only the 4L lamp.
By suggestions of great guys here i swapped the fuel sender pcb of the "new" instrument with the one of the old instrument. Since it was not working and due to replacement of the fuel pump and fittings i did purchased a used fuel sender from Motorworks and replaced that too.
Nada. Nothing.
I get no 4L warning.
Should i try to find an instrument with the 7L + 4L or there is a chance to make this one work?
Thank you
The story
Nada. Nothing.
Thank you
K100RT (Early 1985 -nonABS)
