Number of posts : 7967
If you put the VIN and model in your signature it will help those that will answer the question for you.
The oil/water pump does have a rebuild kit but early ones usually end up needing a new shaft. impeller, seals and be aware the ceramic seal is so easily broken........great care is needed to do it successfully. If its working you could leave it well alone but on almost all Ks its a case of when it fails, not if.
There are lots of other things to do if you have the bike apart that are simple, such as sprag clutch clean, inspect output shaft rivets [again there is a 6/12 rivet issue depending on year],
1971 Yamaha 125 YAS-1
