1Back to top Go down   WANTED Guinea pig with own dyno Empty WANTED Guinea pig with own dyno Sat Jul 07, 2018 10:00 pm
MarcS
MarcS
https://www.magnumtuning.com/en/detail/evo-tech-motorcycle-performance-chip/bmw/k100-w--early-k-jetronic-inj-
They are claiming significant performance gains on Facebook. I would love to see actual dyno figures.
K100rt ex plod bike 5/1990.
I have no problem with authority. Just some of the morons that are paid to enforce it.
2Back to top Go down   WANTED Guinea pig with own dyno Empty Re: WANTED Guinea pig with own dyno Sat Jul 07, 2018 11:01 pm
They are talking shit they don't even know it's an L Jetronic and they don't have oxygen sensors and they aren't digital so you cant chip them.
3Back to top Go down   WANTED Guinea pig with own dyno Empty Re: WANTED Guinea pig with own dyno Sat Jul 07, 2018 11:52 pm
MarcS
MarcS
I thought it might be snake oil. I put a cheap chip on my Nissan Patrol (DI) wagon and it did nothing. I also fitted one to my common rail cab chassis, it then smoked the tyres across an intersection and scared the crap out of me lol.
I did read somewhere that chips make no difference to a K bike.
I have also read that extending duration of the inlet valves and reducing the duration of the exhaust valves will give a few horses, as will advancing the ignition timing a few degrees. These mods are supposed to give better fuel consumption figures too. I have never found a performance mod that gave me better fuel consumption lol. All the extra HP get used Embarassed
4Back to top Go down   WANTED Guinea pig with own dyno Empty Re: WANTED Guinea pig with own dyno Sun Jul 08, 2018 12:05 am
I run all my Ks 4° advanced it makes a heap of difference in the bottom end and retarding the inlet cam one tooth should give more in the top end but I have never tried it.
The K100s that were made for the North American market had different cams that made the inlet open 20° later which effectively reduced the compression ratio and the combustion temperatures which produced less oxides of nitrogen.
5Back to top Go down   WANTED Guinea pig with own dyno Empty Re: WANTED Guinea pig with own dyno Sun Jul 08, 2018 1:26 am
what i gather they are trying to do ...is interrupt the air temp sensor
and trick the ecu into running richer ….hmm   not snake oil but close to with le-jetronic
but they claim fuel savings ...hmm    more fuel = more horsies ?
6Back to top Go down   WANTED Guinea pig with own dyno Empty Re: WANTED Guinea pig with own dyno Sun Jul 08, 2018 7:12 am
Go for Rick's advance; mark the current position of the HES plate and then advance it so that there's 6mm between the inner and outer marks. It has a tendancy to make a standard engine feel like a bit of a slug off the line. Retarding the inlet is too much like hard work for me Smile
7Back to top Go down   WANTED Guinea pig with own dyno Empty Re: WANTED Guinea pig with own dyno Sun Jul 08, 2018 9:17 am
And the direction of advance is counter-clockwise as viewed from the front of the engine, Dai??
8Back to top Go down   WANTED Guinea pig with own dyno Empty Re: WANTED Guinea pig with own dyno Sun Jul 08, 2018 10:23 am
The engine turns counter clockwise looking at the front so the plate has to go 3mm clockwise to advance it 4°
This is the plate in the normal position.
WANTED Guinea pig with own dyno Hall_s10
9Back to top Go down   WANTED Guinea pig with own dyno Empty Re: WANTED Guinea pig with own dyno Sun Jul 08, 2018 3:16 pm
Sh!t - typo. Sorry guys and thanks Rick.
