1Back to top Go down   RS Mirror pod Empty RS Mirror pod Fri Dec 08, 2017 3:41 am
DaleRT
DaleRT
Hi, been doing some tinkering on the RS, after someone knocked of my r/h mirror pod and broke the lens.
   Not being able to get hold of any lenses, decided to make something. I do like the style / look of the RS.
Thought i'd share it - to have ideas thrown around or
   Someone with experience may have suggestions [ like dont attemp it ]
   It did prove very time consuming but i'm satisfied with the result.
RS Mirror pod Img_2019
   The Indicators  Motorcycle LED Turn Signal Blinker Front Rear Peg Light
      Measurement : - Len size: 38mm x 22mm x 10mm - Wire Length: Approx. 28cm Seller: mfactory.
RS Mirror pod Img_2020
   The Light  2pcs 18mm Motorcycle 3W LED Eagle Eye Daytime Running DRL
RS Mirror pod Img_2021
   I left the original hardware, just in case the Lenses do come available
RS Mirror pod Img_2022
RS Mirror pod Img_2023
RS Mirror pod Img_2024
RS Mirror pod Img_2025
The mirror pods themselves did not get damaged because [as suggested] i fitted a lanyard.
   So all is well,   Cheers   Dale
2Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Fri Dec 08, 2017 4:16 am
wow  great result dale
have something very similar in mind for the red frame project
hmmm  looks like there a few more under the fairing upper as well .... care to ...ahem  ...illuminate us ?  giggle
3Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Fri Dec 08, 2017 9:50 am
Bigsax
Bigsax
Awesome!!
I tried modifying my original lenses but found they were too brittle (30 yrs old, go figure) and gave up having achieved nothing except breaking them.
These look great, and I love the yellow!
I took a different path with mirrors/indicators and here is a pic I took tonight just at sunset.
RS Mirror pod 20171210n
RS Mirror pod Brick110
I stole this image, let me know if you want it back.
4Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Fri Dec 08, 2017 9:53 am
Bigsax
Bigsax
Anyone let me in on how I can rotate the pic?
5Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Fri Dec 08, 2017 11:25 am
I just saved and reposted it - did nothing else
RS Mirror pod Ir-log10
 ;BMW; K1200RS Red
6Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Sat Dec 09, 2017 10:47 pm
charlie99 wrote:wow  great result dale
RS Mirror pod 44271
Great job on the indicator lenses, but I wanna know what's under the fairing nose, too. That looks like a real bright idea!
7Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Sun Dec 10, 2017 6:58 am
DaleRT
DaleRT
Out enjoying Cliff drive.
RS Mirror pod Img_2029
  Get back as soon as can with details.
RS Mirror pod Img_2030
  What a shame, can not see the Three Sisters [rock formation, Katoomba] in back the ground.
RS Mirror pod Img_2031
  Cheers   Dale
8Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Sun Dec 10, 2017 7:20 am
RS Mirror pod 44271
sure to draw attention ...well dome mate
9Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Sun Dec 10, 2017 11:26 am
Where did that black lens come from???
10Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Mon Dec 11, 2017 6:12 am
DaleRT
DaleRT
I shall Enlighten you then...
   I made a bracket using existing holes. The drawing is not to scale its just to illustrate the bracket i made.
RS Mirror pod Img_2039
   I wanted to keep the Lights discreet not make a show of them.
RS Mirror pod Img_2040
RS Mirror pod Img_2041
RS Mirror pod Img_2042
   They are wired up as: The 3 LED light is wired to the Park light.
      The light in the mirror pod is wired to headlight low beam
         and the spot light is wired to the headlight high beam.
                        Regards   Dale
11Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Mon Dec 11, 2017 6:48 am
Looks great Dale.
Question: Does the white light in the mirror pod go off when you turn the indicator on?
12Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Mon Dec 11, 2017 7:00 am
RS Mirror pod 112350   thanks dale ...good job
I'm working on a simple circuit for that gaz ...might take some time though , depending on moving in the next month or so
13Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Mon Dec 11, 2017 11:56 am
Did you use the original turn signal lens to install the LED unit in the mirror pod?
14Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Tue Dec 12, 2017 4:57 am
DaleRT
DaleRT
To Shed a bit more light on this subject -
   Gaz - The white light does not go off when indicator is on. Had not thought of doing that.
   Several attempts, mistakes and time later, ive settled on what i have.
      But some food for thought -
RS Mirror pod Img_2043
LED indicator that sticks on, modeling clay on mirror pod.
RS Mirror pod Img_2044
Played around with it. Trying different shapes.
RS Mirror pod Img_2045
RS Mirror pod Img_2046
Tried a full cover
RS Mirror pod Img_2047
RS Mirror pod Img_2048
RS Mirror pod Img_2049
I did not like this attempt - but maybe ideas for others.
Point-Seven-five, What i did to get the shape was to take a copy of the lense in place.
   Then using modeling clay, worked the shape from there.
RS Mirror pod Img_2051
Hope this is of use.   Dale
15Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Tue Dec 12, 2017 6:26 am
Dale I reckon you've started a cottage industry now that the lenses for the RS mirrors are supposedly unobtainable.
Just shows that if someone is prepared to put the time in most challenges can be overcome.
16Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Tue Dec 12, 2017 10:59 am
Dale, that is brilliant!  Once you had the modelling clay form what did you use to create the "lens".  Fiberglass, acryllic resin?
As more owners come up against the lack of replacement lenses  and mirrors, good tutorials on repair options for this critical assembly will become more valuable.
17Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Sun Dec 17, 2017 7:54 pm
DaleRT wrote:Out enjoying Cliff drive.
Cheers   Dale
RS Mirror pod Imag3310
I love riding round Katoomba, and was there only just last trip home. Pamela had never been there. The Sisters are just beyond...
18Back to top Go down   RS Mirror pod Empty K100RS & K1100RS mirror pod Lenses. Tue Mar 27, 2018 2:33 pm
mike d
I have just seen the following on the K1100 forum.......
http://k11og.org/forum/viewtopic.php?t=13067
A possible source for replacements?
Not seen them, so no idea of the quality and if the certain legal markings required in some countries.
Mike
19Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Tue Mar 27, 2018 7:11 pm
Yeah, might be a bit of drama in countries with MOT and roadworthy inspections, but in Los Estados Unidos they'd be no problem. Since BMW cannot supply them why not give them a go?
If anyone who's a member of that forum would be kind enough to enquire of him, get his contact details, I'll try a coupla sets...
20Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Tue Mar 27, 2018 8:40 pm
This is a great substitute for the lens. Terrific job.
RS Mirror pod Frog15RS Mirror pod Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
21Back to top Go down   RS Mirror pod Empty Re: RS Mirror pod Wed Mar 28, 2018 5:10 am
KiwiK100
KiwiK100
Nice work! Very, very impressed. cheers
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
