1 RS Mirror pod Fri Dec 08, 2017 3:41 am
DaleRT
Hi, been doing some tinkering on the RS, after someone knocked of my r/h mirror pod and broke the lens.
Not being able to get hold of any lenses, decided to make something. I do like the style / look of the RS.
Thought i'd share it - to have ideas thrown around or
Someone with experience may have suggestions [ like dont attemp it ]
It did prove very time consuming but i'm satisfied with the result.
The Indicators Motorcycle LED Turn Signal Blinker Front Rear Peg Light
Measurement : - Len size: 38mm x 22mm x 10mm - Wire Length: Approx. 28cm Seller: mfactory.
The Light 2pcs 18mm Motorcycle 3W LED Eagle Eye Daytime Running DRL
I left the original hardware, just in case the Lenses do come available
The mirror pods themselves did not get damaged because [as suggested] i fitted a lanyard.
So all is well, Cheers Dale
