1 Wanted to buy or borrow: 2 valve muffler with heat shield cover intact (YEARS 1983, 1984, 1985 only) Sat Dec 09, 2023 5:56 pm
Chris350
I'm located in Calgary, Alberta, Canada.
I have an '85 K100 which I'm hoping to have ready for an out of province inspection (Alberta, Canada) in the summer/fall of 2024. One of the inspection items is an exhaust system with heat shield cover intact.
My '85 has the stock exhaust but the heat shield has been removed and tabs ground off before I got it.
I'm looking to either buy or locally borrow the 2 valve stock exhaust with heat shield. Doesn't need to be pretty it just needs to be decent enough to pass this inspection. I'll re-install the one I have now after the inspection. If someone does have one to lend me, you can borrow mine so you can keep riding!
FWIW... my current muffler part number is Gillet 3087 18121451528.
Let me know what you got.
Thanks,
Chris
Thanks,
Chris
