1Back to top Go down   Valves for Rims Empty Valves for Rims Sat Feb 24, 2018 3:34 pm
DBRMN
DBRMN
Hey guys does anyone know the best place to get valves for my rims (1991 BMW K100LT ABS)  as my local tire places doesn't have the right ones.
DBRMN
2Back to top Go down   Valves for Rims Empty Re: Valves for Rims Sat Feb 24, 2018 3:49 pm
36 31 7 653 064 is the BMW part number, but any 15mm-wide base rubber or metal valve stem will work on BMW Y-spoke and three spoke wheels. Real Oem and Max BMW online show them retailing for about $9.00 USD each. Motobins have them for £5.10 each Part No. 59999.
If they're not the rubber version then use Motobins part number 59980 for even less money.
Last edited by Two Wheels Better on Sat Feb 24, 2018 3:56 pm; edited 4 times in total
3Back to top Go down   Valves for Rims Empty Re: Valves for Rims Sat Feb 24, 2018 3:51 pm
DBRMN
DBRMN
Two Wheels Better wrote:36 31 7 653 064 is the BMW part number, but any 15mm-wide base rubber or metal valve stem will work on BMW Y-spoke and three spoke wheels. Real Oem and Max BMW online show them retailing for about $9.00 USD each.
Perfect Thank you.
4Back to top Go down   Valves for Rims Empty Re: Valves for Rims Sun Feb 25, 2018 10:02 pm
Rickmeister
Rickmeister
For what it's worth, I finished up putting right-angled valves on the rim with the last tyre change. It makes it MUCH easier at the servo when checking tyre pressures!
5Back to top Go down   Valves for Rims Empty Re: Valves for Rims Sun Feb 25, 2018 11:09 pm
Do not use the rubber pull through right angle ones. I had one split at the rim resulting in rapid air loss on the highway.
6Back to top Go down   Valves for Rims Empty Re: Valves for Rims Mon Feb 26, 2018 5:45 am
BobT
BobT
MartinW wrote:Do not use the rubber pull through right angle ones. I had one split at the rim resulting in rapid air loss on the highway.
That is like saying do not buy a K100 because I had one break down! One split valve does not make a trend or an epidemic.
7Back to top Go down   Valves for Rims Empty Re: Valves for Rims Mon Feb 26, 2018 6:14 am
Actually, I mirrored Martin's experience so his is not an isolated case,  I had the mechanic fit pull-through right angle valves on my K75 rims and both failed at speed, albeit only slowly leaking air. I now only use all-metal short straight valves.
8Back to top Go down   Valves for Rims Empty Re: Valves for Rims Mon Feb 26, 2018 6:47 am
The ones that clamp in with the nut are far safer. The tyre supplier that replaced the stuffed front tyre had previously experienced problems with that type of valve and will no longer fit them. Definitely not an isolated case. The problem lies with inflating them. Pushing on the air supply eventually weakens the rubber were it goes through the rim, eventually causing a tear and failure. With the straight pull through ones you are pushing straight on and it is a lot less likely to tear the valve.
9Back to top Go down   Valves for Rims Empty Re: Valves for Rims Mon Feb 26, 2018 9:29 am
Now it's an epidemic. Laughing
10Back to top Go down   Valves for Rims Empty Re: Valves for Rims Mon Feb 26, 2018 4:34 pm
Oh crap.
The start of another tyre thread.
I don't use them either. Right angle valves that is.
11Back to top Go down   Valves for Rims Empty Re: Valves for Rims Tue Feb 27, 2018 5:32 pm
DBRMN
DBRMN
Just tried to order through MOTO-bins got this after 'paying':
Valves for Rims Screen10
Tries again got the same message so I've contacted them I'm not gonna try again in case its actually taking money.
12Back to top Go down   Valves for Rims Empty Re: Valves for Rims Wed Feb 28, 2018 1:19 pm
DBRMN
DBRMN
Tried again after talking with them think it went through so I'll attach pictures when I get them and the tyres back on.
13Back to top Go down   Valves for Rims Empty Re: Valves for Rims Wed Feb 28, 2018 4:39 pm
I carry a BMW-supplied right angle tire valve that threads on temporarily. It's too heavy to leave on the wheel and isn't intended for that use anyway. It makes reaching in between the wheel spokes of various Beemers a helluva lot easier given the variety of air nozzles at servos. Part number 71 11 1...something or other. Also available from Amazonia the Destroyers for under $4 a set.
Valves for Rims Right_10
14Back to top Go down   Valves for Rims Empty Re: Valves for Rims Thu Mar 01, 2018 3:49 am
KiwiK100
KiwiK100
I would recommend valve change with every tire change. I had a valve dismantle itself while riding, fortunately it was the rear and all ended well. The brass valve fitting parted company with the rubber housing on my K1200RS resulting in rapid massive air loss, at speed.... It can, and does happen.
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
