1 Question on headlights Fri Feb 16, 2018 3:23 pm
StefanMajonez
Hi! I have a question. The bike is a 1994 K1100LT.
For a bit of background, last evening I have done a relay upgrade to my headlight, using 18A automotive relays with a 15A automotive fuse (in the relay compartment below the tank), all connected and properly isolated and secured, etc.
Now for the question proper - can I run100W bulbs in there? As I've read on this forum (and on motobrick), some users say it's completely fine and problem-free. Despite that, I still am not entirely sure about going forward with those higher-wattage bulbs.
My main concern is heat. Will the OEM BMW H4 holding bracket survive the higher temperatures? What about the reflector itself, of the glass up front? I've read horror stories of headlight glass breaking when splashed with water because of the added heat of a100W bulb.
I'd just like to hear from more experienced K-bike owners regarding the headlight assembly quality and resilience to heat. Thanks in advance.
EDIT:
Reading up on the subject, and thinking about it, I probably won't put a 100W bulb in my bike - the heat issues and legality of it. Are there any other reliable ways to get a proper quantity of light out of a headlight? Does simply buying quality lightbulbs help significantly?
EDIT:
1994 - BMW K1100LT
Dyno results 2017
Previous bike:
1989 Honda CB450S
