1Back to top Go down   Possible MAF sensor fault Empty Possible MAF sensor fault Sat Jan 27, 2018 11:27 pm
Last Monday I started experiencing intermittent rough running and surging. I stopped and filled it up hoping that it was a low fuel problem. It would run fine for a while and then it would start playing up. Took it for a short ride on Friday and the symptoms disappeared. Yesterday the symptoms returned, so thinking I had dirty injectors I swapped them for a spare refurbished set and cleaned the fuel rail. Injector swapping did not change the symptoms. I decided to look a bit further and I set the revs to 1000 rpm which could only be reached by using the fast idle. Once set at 1000 rpm I hit the green start button and the engine immediately lost revs and died. Pressing the green button enriches the mixture, so it was running too rich. Inspecting the tailpipe confirmed this, it was black. So with this evidence I believe I have sticky MAF problem. Before I start delving into the MAF, am I on the right track? And do I have to pull apart the MAF to clean it, or is there another way? And if I do have to pull it apart  what should I be looking for.
2Back to top Go down   Possible MAF sensor fault Empty Re: Possible MAF sensor fault Sat Jan 27, 2018 11:41 pm
you don't have a pinched - bent over return fuel line  or anything after the fuel rail that could add restriction ?
3Back to top Go down   Possible MAF sensor fault Empty Re: Possible MAF sensor fault Sat Jan 27, 2018 11:48 pm
Or a bad temp sensor (or its connections).
4Back to top Go down   Possible MAF sensor fault Empty Re: Possible MAF sensor fault Sun Jan 28, 2018 12:05 am
Inge K. wrote:Or a bad temp sensor (or its connections).
+1
5Back to top Go down   Possible MAF sensor fault Empty Re: Possible MAF sensor fault Sun Jan 28, 2018 2:41 am
Thanks guys I'll check the return line first as I had to reroute it when I fitted the cooler. I've had previous connector problems (twice in twenty  years) but the bad temp sensor connection but it caused it to over fuel on start up, flooding the engine. The only way to start it was to remove the fuel pump fuse and replace it as the engine started to die. I'll give it a go though.
Regards martin.
6Back to top Go down   Possible MAF sensor fault Empty Re: Possible MAF sensor fault Mon Jan 29, 2018 12:00 am
Possible MAF sensor fault 723598 Easy fix, thanks guy's, once Charlie suggested return line I went straight to it this morning. When I fitted my fuel cooler I had to reroute the line about 4-5 times to try and get it to stop kinking. Eventually with a longer hose and a total reroute I got it to stop kinking. It was fine for a couple of weeks. However on the day that it started to play up I was running in traffic and I saw 39C on the dash mounted temp gauge. The very thing that I had made to cure the hot running problem was my down fall. Possible MAF sensor fault 177381 Due to the excess heat the hose collapsed. I went and bought some heavier hose but I am not going to mount it back until I can source a spring to go around the outside of the hose, preferably stainless steel. You use to be able to get them from hydraulic shops, so I am now on the hunt. The guy across the road from me has a mobile hose repair business so I'll try him first. Possible MAF sensor fault 112350
Thanks fellas regards Martin.
7Back to top Go down   Possible MAF sensor fault Empty Re: Possible MAF sensor fault Mon Jan 29, 2018 2:53 am
like like
Possible MAF sensor fault Frog15Possible MAF sensor fault Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
8Back to top Go down   Possible MAF sensor fault Empty Re: Possible MAF sensor fault Mon Jan 29, 2018 6:20 am
