1 Karamba speedometer calibration program Sat Apr 02, 2011 8:09 pm
I calibrated my speedometer using Karamba today. It is a really great piece of software which I haven't seen discussed on this site so I'm wondering if anyone here knows about it.
Karamba is written by Michael Köcher (six1) and Peter Stefan (Pezi). It is available for download from the Köcher Elektronik web site. The purpose of Karamba is to calibrate a K-bike speedometer and verify that both the speedo and odometer are functioning properly.
The program runs on a PC with Windows XP or Windows 7. The PC interfaces to the motorcycle through the connector joining the speed transducer in the final drive to the main wiring harness. It is necessary to manufacture a very simple cable to connect the plug on the motorcycle to the PC through the 3.5mm audio output of the sound card. The main page of Karamba looks like this:
Once the PC is connected to the speedometer through the transducer connector, and power is applied to the bike, then it is possible to select various road speeds in the software that will cause the speedo to operate and display those speeds as well as get the odometer to start to register distance.
I used the software to display a variety of speeds on my speedo so that I had assurance that the speedo was calibrated properly for my tire size. Really quick and easy to setup and use.
Has anyone else used this software before?
