1Back to top Go down   The road melting Empty The road melting Sat 13 Jan 2018, 20:56
Warning to anyone out towards Wivenhoe, the roads are melting and coming very loose in the corners.
2Back to top Go down   The road melting Empty Re: The road melting Sun 14 Jan 2018, 00:19
yeah was pretty warm mate
this at 12.30  round about and just home from Mt Glorious
The road melting 20180129
3Back to top Go down   The road melting Empty Re: The road melting Sun 14 Jan 2018, 00:29
Andrew2
Andrew2
What brand thermometer is that Charlie?.
1987 K100RS
4Back to top Go down   The road melting Empty Re: The road melting Sun 14 Jan 2018, 01:18
um ex supercheap auto   accuracy is fairly close to standards , fairly quick reaction time also
got it cheep as they deleted the item from inventory  however there may be still some around , look in the bargain bin ,
this one took a tumble at about 110kph  on the way to Kaputar ...slid about 50 meters end over end  and a slight crack in the clear window , but still works ...omg
cost me 3.95 ...yes really ...I nearly fell over backwards ...(note blacks out when over 50 c direct sunlight  , saw that a couple of times today whilst parked )
usually the positive wind force that I have created behind the big fairing keeps the readings about atmosphere temps
but when I first got the rt ..the temps were unreal as the design sucks air from down near the motor - radiator  into the vacuum bubble  behind the windscreen , advantage in sub 20 degree temps ....but not out here , in my area at least
top display is in the device ,
lower display is a remote sensor iv located just outside the fairing lowers ....climbs pretty quick after stopping if left on side stand ...grin
5Back to top Go down   The road melting Empty Re: The road melting Sun 14 Jan 2018, 01:24
The road melting 259495
6Back to top Go down   The road melting Empty Re: The road melting Sun 14 Jan 2018, 02:12
Try Jaycar I bought a thermometer only for $10.00, but I think they have other models.
7Back to top Go down   The road melting Empty Re: The road melting Sun 14 Jan 2018, 02:23
yeah so did I martin   a dual scale jobie
but discontinued 3 years ago   was under 20
8Back to top Go down   The road melting Empty Re: The road melting Sun 14 Jan 2018, 10:51
I bought mine last week $9.95 C or F.  https://www.jaycar.com.au/digital-lcd-mini-thermometer/p/QM6323The road melting Digita10
Popped of the little hook thingy and velcroed  it to the dash pad. Thought it might come in handy for the fuel cooler testing. I also bought one for testing temperature sensors and whatever else I can boil or freeze $10.95. https://www.jaycar.com.au/lcd-probe-thermometer/p/QM7314
Regards MartinThe road melting Lcd-pr10
9Back to top Go down   The road melting Empty Re: The road melting Sun 14 Jan 2018, 11:00
nice !
10Back to top Go down   The road melting Empty The road melting, Sun 14 Jan 2018, 12:48
Er, just to be a bit different, went for a spin on my new steed (yes, I have turned again, at least it has a shaft), and  I had to have my heated handgrips on, but I balked at the heated seats. This is after similar temps to you guys just a couple of days ago.
I should have known, had my usual no.2 haircut mid week. Always a sign of temp drop.
Keep safe
11Back to top Go down   The road melting Empty Re: The road melting Mon 15 Jan 2018, 00:20
RT, by the sound of that last post of yours you need to update your signature line and let us all into the secret of what vehicle in your possession has both heated grips and heated seat !!!!!
12Back to top Go down   The road melting Empty Re: The road melting Mon 15 Jan 2018, 00:27
psst  I had an sms from bob  saying something about either a r bike or an r bike ...
ill let him disclose the details ...perhaps
I don't know for sure ,  but after seeing WAZ's shed of motors vehicles , he may have had a lot to do with bobs choice
13Back to top Go down   The road melting Empty The road melting Mon 15 Jan 2018, 13:24
Sorry to hijack this one. 2011 R1200RT. not sure if it's SE like Rickmeisters. Photo coming if I can get around to it.
48k on clock. Not sure what came over me. Maybe cleaning the crud off my Suzie's chain helped.
14Back to top Go down   The road melting Empty Re: The road melting Mon 15 Jan 2018, 14:14
RT wrote:Sorry to hijack this one. 2011 R1200RT. not sure if it's SE like Rickmeisters. Photo coming if I can get around to it.
Maybe the desire to make the bike match the initials again?  The road melting 652573
