1Back to top Go down   Oil pressure switch rubber cap Empty Oil pressure switch rubber cap Fri Jan 05, 2018 7:36 am
Hello all
While repairing the water pump on the K
I damaged the rubber cap that seal the terminal on the oil pressure switch
Anyone know where or what replacement will work to seal it from crud ?
2Back to top Go down   Oil pressure switch rubber cap Empty Re: Oil pressure switch rubber cap Fri Jan 05, 2018 8:01 am
That is quite a common type of cap Matt, I reckon most auto stores would be able to find one or maybe even have one.
3Back to top Go down   Oil pressure switch rubber cap Empty Re: Oil pressure switch rubber cap Fri Jan 05, 2018 8:17 am
4Back to top Go down   Oil pressure switch rubber cap Empty Re: Oil pressure switch rubber cap Fri Jan 05, 2018 12:46 pm
The BMW part number for the cap is 61 13 1 363 318 and is listed at less than US$2.00, so that'll be ten dollars Down Undah.
5Back to top Go down   Oil pressure switch rubber cap Empty Re: Oil pressure switch rubber cap Fri Jan 05, 2018 6:22 pm
Thank you
6Back to top Go down   Oil pressure switch rubber cap Empty Re: Oil pressure switch rubber cap Fri Jan 05, 2018 8:05 pm
TWB, you have to let on where you get your parts because I want to get mine there too.
The Max BMW parts fiche shows that part for a mere $6.21US.
7Back to top Go down   Oil pressure switch rubber cap Empty Re: Oil pressure switch rubber cap Sun Jan 07, 2018 3:33 pm
Point-Seven-five wrote:TWB, you have to let on where you get your parts because I want to get mine there too.
eGahds! Bitten by realoem.com yet again! They show it as $1.77. Clearly they're not keeping up with current pricing - BMWNA does quarterly updates to their dealer pricing chart.
T'other day I needed a combi switch and realoem had it at retailing for $132 when it is now priced at $185. Still, the rubber boot is currently available, and not terribly expensive. Since they fit all early Ks oil pressure and water temp switches I keep two in my spares bin.
