1 Clutch Release Boot Leak K100RT Sat Dec 23, 2017 9:09 am
flyinglow
On my 1985 K100RT it has a occasional drip of gear oil from the rubber clutch release boot so it gets messy. This bike has 30,000 miles. The clutch works fine and I just replaced the clutch cable. I found on the forum an article listing Service Bulletin 2100689 (2335) which talks about gear oil leaking from the rubber boot. Essentially it says the leak is generally caused by the clutch free play being incorrectly adjusted. All that is needed is to remove the boot, clean and replace and correctly adjust the clutch. Does this procedure generally stop this leak? Any additional input on this?
