1 Question about Karamba Mon Dec 18, 2017 11:54 am
propav8r
Hi all, just getting ready to test my inop K100 speedo with Karamba, and wanted a little clarification...
This thread: https://www.k100-forum.com/t2038-karamba-speedometer-calibration-program-tutorial
Says you should connect power to pin 6, speedo signal to pin 22, and ground to 23.
Now, I'm a little confused here...power is 12v from a benchtop transformer to pin 6. That's easy enough.
Signal to pin 22...is this the tip/ring of the special cable? (yellow wire in image)
Ground to pin 23...surely this goes to the ground of my benchtop transformer, yes? Where should I connect the ground pin of the audio plug? Also to pin 23? (black wire in image)
