Ok, Here is some of the up front details
After talking to Miss kelley she sold me one for AUD$649.00 delivered.
Certification:CE
Feature:Non-Toxic
Fuel:Electric
Cleaning Process:Solvent Cleaning
Material:Metal / Coil
Model Number:JP-100S
tank material:SUS304
timer:0~30min,adjustable,digital
heater:0~80C,adjustable,digital
power supply:110~240V
stainless steel basket:optional (but included)
ultrasonic power:500W
ultrasonic transducer:10pcs
tank capacity:30L with 3/8 drain tap.
Also a stainless lid.
I bought this unit from Miss kellies'online Goodclean Tool,s Store as she was fast to respond and answer my questions. Also She takes PayPal and the EMS shipper acts as Escrow so your money is held untill you receve the goods. Shipping was about eight working days.
As for performance, I goofed a bit and ordered detergent!! Not degreaser. The Chem I ordered was 815 GD is a standard immersion and ultrasonic detergent cleaner - (thatll learn me to order while tired.
I meant to order 815QR a Heavy Duty immersion and ultrasonic detergent cleaner -PDF
Here . Safe for a lot of Alloys!!!
It worked out around $23.00 a tank I looked into Simple Green as well. nearly
Chocked!! At a ratio of 1:1 for heavy duty cleaning, not cheap.
Here is a pic of the Foil Test to check that all is working sound wise. Notice the perferations in the foil? not wise to put fingers in tank while running.
The tank drains well but It would be better if it was dished? around the drain hole to help remove sediment.
I had an old carby lying around that had some junk in it and on it.
Before...
And after ,,
Some of the deep cavities stil had some oxidisation and the alloy was stained from age. This can be removed with soda blasting. The valves now all work freely and all springs as well. i am just going to have to wait for a reason to pull bike apart before i can drop some of her parts in. Any really heavy grease needs to washed off first. I have come to teh
conclusion that this is a part of the process that can determine the
results. I dropped one of the foot peg brackets in with car wash and it came up fairly clean. i am sure I have missed a lot, so Any questions please ask.
