1 cheap cruise control Sun Oct 22, 2017 4:36 pm
kiekuut
how to make a cruise control out of a old innertube
for k100rt 85
there is a small plastic under the trotlle when you remove it you wil see the same tred as the valve of a inner tube
take a old valve mount the inner valve the other way with a bit of glue , you now have a screw with a little point
screw it in the handle slide a spring arond it and screw the nutt on so it will not unwind
now glue the valve covver and adjust it so you can fix the gas in any position
best regards Eddy
for k100rt 85
best regards Eddy
