1Back to top Go down   cheap  cruise control Empty cheap cruise control Sun Oct 22, 2017 4:36 pm
kiekuut
kiekuut
how  to  make  a  cruise control  out  of  a old  innertube
for  k100rt 85
there  is  a  small  plastic  under  the  trotlle    when  you  remove  it  you  wil  see  the  same tred  as  the  valve  of  a  inner tube
take  a  old  valve  mount  the  inner valve  the  other way  with  a  bit of glue  , you  now  have  a  screw with  a  little  point
screw  it  in  the  handle  slide  a  spring  arond  it  and  screw the  nutt  on  so  it  will  not  unwind
now  glue  the  valve  covver  and  adjust  it  so  you  can  fix  the  gas in  any  position
best  regards  Eddy
2Back to top Go down   cheap  cruise control Empty Re: cheap cruise control Sun Oct 22, 2017 6:08 pm
great tip.
cheap  cruise control Frog15cheap  cruise control Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   cheap  cruise control Empty Re: cheap cruise control Sun Oct 22, 2017 10:28 pm
Or alternatively,
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=6&Q=%0932721454414&x=0&y=0 is the BMW OEM part that does the same job
cheap  cruise control Thrott10
BMW part number 32721454414
4Back to top Go down   cheap  cruise control Empty Re: cheap cruise control Sun Nov 26, 2017 2:00 am
GF Wollongong
GF Wollongong
I included one of these screws in a recent motobins careflight package.
couldn't see where it went ... then got distracted by something else
Not to worry, my RS throttle is neutral - it has an inbuilt cruise control and allows me to let go of the throttle and continue at same speed.
So for now, I'm leaving well enough alone and might use it for the RT whose engine lies gutted on a bench (...still!)
And how's the K1100 going, Bill?
Guy
5Back to top Go down   cheap  cruise control Empty Re: cheap cruise control Sun Nov 26, 2017 2:53 am
I didn't like the OEM one too hard to get to especially with gloves. So I made one that is safer and easier to use.
Regards Mcheap  cruise control Thrott10artin.
6Back to top Go down   cheap  cruise control Empty Re: cheap cruise control Sun Nov 26, 2017 3:03 pm
cheap  cruise control 20171162
Go Cruise. It rests on the front brake lever when you've decided what RPM you're gunna 'cruise' at. US$20 for the plastic version. They also make an aluminium version for about $30. When you're done with that one then simply turn the silver ally bit at the end of the 'bar. It's a Throttle Meister. Costs much more, but about as effective as the Go Cruise. On some bikes it helps reduce handlebar resonance/vibrations. If you really wanna go cheap, fit a rubber o-ring of appropriate thickness between the 'bar end weight and the throttle tube for added resistance: obviously not adjustable for tension.
